Thread Number: 167
Frog-Eyed Kenmore |
Post# 45917 , Reply# 1   9/27/2004 at 20:46 (7,150 days old) by coldspot66 (Plymouth, Mass)   |   | |
According to the model#, it should be 1955. |
Post# 45918 , Reply# 2   9/27/2004 at 20:48 (7,150 days old) by TrainGuy (Key West, FL)   |   | |
Post# 45941 , Reply# 3   9/28/2004 at 07:49 (7,149 days old) by Gyrafoam (Wytheville, VA)   |   | |
I appreciate your information! Now if I could just figure out why it apparently has both timed fill and a pressure switch!!! -Steve |
Post# 45945 , Reply# 4   9/28/2004 at 08:38 (7,149 days old) by Unimatic1140 (Minneapolis)   |   | |
Steve, Kenmore & Whirlpool washers have never had a timed fill. The Dial is marked "FILL" only where the machine will fill, but it wont start to agitate without satisfying the float or pressure switch. There is an area on the timer knob that is not marked fill is so you can advance the timer knob and start agitation at a lower water level, sort of like the Water Saver Button on late 1950's GE washers.
