Thread Number: 16886
Maytag Top Loader problem |
Post# 278412   5/5/2008 at 10:37 (5,834 days old) by iheartmaytag (Wichita, Kansas)   |   | |
Last Thursday my Maytag Dependable Care Plus sprung a leak. I have been having problems with water around the machine but it wasn't all the time. I had the repair man out about two months ago, and he thought it was a stuck fill valve so he cleaned it and said all was ok. Well--Thursday night I was standing there watching it fill so I knew it hadn't overflowed when I noticed water coming from the bottom of the machine. I took the front off and water was pouring from the center where the agitator shaft goes through. I have called the service man, but some are saying the washer is toast. That the leak probably took out the transmission. Is this true? I am really not in the position to buy a new washer at this time even if I wanted one (which I don't). I'm just trying to prepare myself for the worst, so I will be happy when the lesser happens. The machine is only 13 years old, I expect at least another 20 years out of it. I average about one load a day. I say one, becasue there are days I don't wash, then there are days I do seven loads when I strip beds etc. I think the old girl still has a lot of life left in her. Let us Pray. |
Post# 278418 , Reply# 1   5/5/2008 at 10:56 (5,834 days old) by volvoguy87 (Cincinnati, OH)   |   | |
I'm sure it can be fixed. I don't know how, but it must be possible. If you need a new transmission, I think the new Orbital ones are still available. If you want to get crazy get a used Helical transmission for the large capacity washers and a Power Fin agitator to match. A few seals, maybe a new transmission, certainly not impossible. Dave |
Post# 278422 , Reply# 2   5/5/2008 at 11:19 (5,834 days old) by redcarpetdrew (Fairfield, CA)   |   | |
How many times I see one of my fellow servicemen throw the 'tranny' card out like that as justification for not wanting to do the job... I see alot of tub bearings and seals go bad WITHOUT hurting the transmission. ( The Majority don't ) I have to go out on route this morning so I'm rushed, but I'll try to get back here this PM with part numbers and some advice to try to save your girl... I think we can do it... RCD |
Post# 278440 , Reply# 3   5/5/2008 at 12:19 (5,834 days old) by iheartmaytag (Wichita, Kansas)   |   | |
It looks like a funnel turned sideways under the tub. I am pretty sure it's a helical because it does have the white 12 vain agitator. I am hoping that the water running over the outside the transmission is a good sign, maybe the seal protected it from going inside. The service company just called, they will be out tomorow afternoon. |
Post# 278477 , Reply# 5   5/5/2008 at 15:10 (5,834 days old) by volvoguy87 (Cincinnati, OH)   |   | |
Yours has the newer style transmission. Unless I have them flipped around in my mind, the old one is the Helical and the new one is the Orbital. If I am right, the Orbital is the short fast stroke, and the Helical is the long slow stroke. Both are excellent, although I prefer the long slow stroke. Getting my bearings... Dave |
Post# 278482 , Reply# 6   5/5/2008 at 15:28 (5,834 days old) by iheartmaytag (Wichita, Kansas)   |   | |
You may be right Volvoguy. In the brochure when I bought it, it was called the Dependable Care Transmission. I thought the orbital was shorter in profile and rode up next to the tub. The one I have (whichever it is) all sits below the tub. It reminds me of a funnel turned sideways, or if you were looking at an old truck defferential. It was bought new on 5-9-95, I believe the model is LAT 8704. I looked it up this afternoon for the appliance lady setting the appointment. Good new,it seems that my homebuyer's warranty will cover all but $55 of the repairs. That's a big relief. |
Post# 278483 , Reply# 7   5/5/2008 at 15:39 (5,834 days old) by dadoes (TX, U.S. of A.)   |   | |
IHeartMaytag, you have the two tranny styles reversed. Yours is orbital. However, technically, both are helical-drive, which refers to how the motor drives the tranny and spin basket. The orbital tranny design is changed internally, in how the transmission converts the motor's rotation into oscillation of the agitator.
Post# 278489 , Reply# 8   5/5/2008 at 16:17 (5,834 days old) by redcarpetdrew (Fairfield, CA)   |   | |
You indeed have the orbital transmission. I'm glad you have a warranty to fix it and as long as the tech coming out knows what he's doing, you should be ok. Parts that should be replaced:(Refer to picture below) #29 - P/N 22001648 Mounting stem and seal kit (Cause of the leak) #21 - P/N 204013 Tub bearing repair kit (can be damaged by the leak) Addt'l parts that SHOULD be replaced to do the job right: #4 - P/N 200744 Tub bolt & gasket assy (short) QTY 1 - P/N 205254 Tub bolt & Gasket assy (long) QTY 2 When pulling the outer tub to get to the bearing and seal assy's, these bolts should be replaced to avoid possible leak issues later. By the way, these part numbers are good for rebuilding older Maytags, as well... RCD |
Post# 278505 , Reply# 9   5/5/2008 at 18:12 (5,834 days old) by qsd-dan (West)   |   | |
Post# 278510 , Reply# 10   5/5/2008 at 19:08 (5,834 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 278517 , Reply# 11   5/5/2008 at 19:45 (5,834 days old) by qsd-dan (West)   |   | |
Well, I knew there was a shallow and deep tub, but I'm not up to date on the newer transmissions. I have way too much fun with the older tranny's :) BTW, since you have been in the industry long enough to service many orbital and helical transmissions, what is your opinion on the helical vs. the orbital for longevity, reliability, and clean-ability? |
Post# 278544 , Reply# 12   5/5/2008 at 21:51 (5,834 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The Helical Transmission is very bulletproof. The main reason I have to crack one open (and not that often at that) is to replace the lower shaft o-ring seal which can only be done from inside. They have a nice long stroke which is gentler on the clothes and does well with the lint collection with the in the agitator lint filter. I think the older style also has a longer service life due to how it's made and the materials used. That being said, the orbital has it's points, too. Less moving parts, almost completely field serviceable without gutting the washer to get it out and, in it's own way, I think it washes ok. The stroke is faster and shorter but coupled with the Loadsensor (Corkscrew 2 pc) agitator, it moves some of the bulkier loads that the older style transmission had trouble rolling over... The main weakness I see in the orbitals is a bad habit of throwing the lower oil seal and leaking. The oil seal (a lip seal) is relatively easy to change from the bottom once you pull the drive pulley, but even after changing the seal, the leak may re-occur... I'll take the Maytag orbital transmission over the Whirlpool direct drive model any day as all you have to do is sneeze at it and it'll throw the neutral drain pkg out of whack or break one of MANY revisions of the coupler... RCD |
Post# 278674 , Reply# 13   5/6/2008 at 15:08 (5,833 days old) by iheartmaytag (Wichita, Kansas)   |   | |
He was there all of about 10 minutes, pronounced the old girl dead and left. Estimate to fix $585. Exactally the same amount I gave for her 13 years ago this month. He said he didn't think the home warranty will approve this size repair for this old of a machine because they figure a washer's life cycle of seven years. He is going to submit the estimate to them, and maybe because it is a Maytag they may approve it. |
Post# 278692 , Reply# 14   5/6/2008 at 16:54 (5,833 days old) by johnb300m (Chicago)   |   | |
Post# 278709 , Reply# 15   5/6/2008 at 17:28 (5,833 days old) by qsd-dan (West)   |   | |
RCD: Thanks for your detailed and unbiased opinion. I asked Jim the same question, but all of his answers to any appliance were extremely biased in that the newer design was ALWAYS better. Iheartmaytag: I'm guessing he pronounced your orbital transmission dead. The offer still stands for the new (not rebuilt) one I have in the box. |
Post# 278730 , Reply# 16   5/6/2008 at 19:35 (5,833 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Wow. Was that estimate including the supposed bad transmission? Lean the machine back against the wall, remove the drive belt and turn the drive pulley counter-clockwise. The pulley should turn smoothly and easily and the agitator should move.(Did this person even do that?) That should indicate what is most likely a happy transmission. The only way he can properly diagnose a water contaminated transmission is to crack open the cover on it and look for oil blended with water... I see, maybe, 1 in 70 or so 'water in transmissions'. Lets play with some numbers for fun... As far as parts: (in Reno prices) 22001648 subs to 22204012 $52.25 204013 $41.99 205254(qty2)$8.82 200744 $2.97 -------------- total $106.03 Avg Labor @ 1 hr. Est $109.00 -------------- Total $215.03 + tax(Approx) Maybe I'm off base about this. Maybe this guy's on the level. Maybe I should climb off my soapbox, but I hate seeing huge estimates thrown at good machinery causing premature retirement usually due to the repair person not wanting to fix it and instead sell another or being on commission. It does happen. Alot. Time for my chill pill... RCD |
Post# 278814 , Reply# 17   5/7/2008 at 08:30 (5,833 days old) by iheartmaytag (Wichita, Kansas)   |   | |
No this estimate doesn't involve the transmission. Its for a tub seal, bearing and belts. It's the labor that caused him to ram it in without KY. I have to wait for the Home warranty company to decide if they are going to repair or replace it. I really don't want a new machine, but what's a poor guy to do? |
Post# 278822 , Reply# 18   5/7/2008 at 09:25 (5,833 days old) by iheartmaytag (Wichita, Kansas)   |   | |
No he did not lean the machine back. In fact he walked in wrote down the serial and model number. Took the front off the machine, filled it spun out the water, said he would submit the estimate. Total time in the house was less than ten minutes. And he charged me $55 for that. I always thought when I get screwed that fast they should be the ones leaving the money on the dresser. |
Post# 278859 , Reply# 19   5/7/2008 at 15:01 (5,832 days old) by volvoguy87 (Cincinnati, OH)   |   | |
If the warranty company wants to replace it, I say you should start over and get an estimate from a competent service company. If that won't happen, fix the d!@n thing yourself. A Maytag Dependable Care of any vintage is better than the new junk you can buy today. Although Speed Queen top loaders are pretty good, I still think an old Maytag is far better. Even considering the cost of the repair and the age and wear on the rest of the machine, you're still better off with the Maytag. Maytags are easy to service, what's this repair-person's problem? Dave |
Post# 278861 , Reply# 20   5/7/2008 at 15:20 (5,832 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Now you know what's wrong and what's needed to fix it. The rough estimate I posted above shouldn't be that far off. I'd try shopping the local servicers for estimates. Remember, those who operate out of a shop (as opposed to a truck) may charge less if you bring it to them. Doing it yourself isn't so bad as long as you have the Maytag tub nut tool to pull the tub nut and the mounting stem... This guy may also be padding the bill, hoping the insurance co. pays up without question... RCD |
Post# 278907 , Reply# 21   5/7/2008 at 20:44 (5,832 days old) by jaytag (Atlanta)   |   | |
Check your local C list and watch for a Maytag. They come up about once a month here in ATL. You may have to go to KC to pick one up, but you can get them for $100 or less. |
Post# 279562 , Reply# 22   5/12/2008 at 08:53 (5,828 days old) by iheartmaytag (Wichita, Kansas)   |   | |
The home warranty people reviewed the claim, and decided that since it "Was a Maytag and not a disposable machine." They authorized the repair. The old girl is holding her water and washing fine. Total bill $386.94. The repairman told me not to expect more than three or four years from this repair, and that I should take this time to look for a new machine. He said it isn't the machine itself, but he quality of the replacement parts that leaves him to worry that it will last very long. In any case, I didn't have to buy a new washer, and got my money's worth out of the home warranty to boot. |
Post# 279585 , Reply# 23   5/12/2008 at 11:13 (5,827 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 279605 , Reply# 25   5/12/2008 at 12:22 (5,827 days old) by iheartmaytag (Wichita, Kansas)   |   | |
It was a factory part, he showed me the package. He also changed the tub bolts and belts, I watched him. He showed me the part he took off, and the one he was replacing it with. There was a noticable difference in the thickness of the seal. He said on some machines that Whirlcrap was molding the bearing onto the tub so you have to replace the outer tub to fix the problem, which is cost prohibitive. I will just baby the old girl, and pray she holds in there. He suggested I look at the Bosch FL machines. He said he wasn't a salesman, and didn't make a commission; but he said they are very reliable and parts are easy to get if you need them. It's amazing those little things you take for granted, things like clean underwear. |
Post# 279820 , Reply# 26   5/13/2008 at 11:44 (5,826 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Yes, I have to agree that the parts are cheaper such as going to a lip seal for the center seal. I get around that by using the old #A04298 agitator shaft seal WITH the new lip sealed stem. It compresses down nicely and effectively eliminates any worries of re-leakage. What I can't believe is how they've managed to eliminate almost all of the metal from the newer Magic Chef/Norge/Atlantis pump assys yet charge about twice as much for the damn thing... As far as bearings molded into the tub, I know that Whirltag would LOVE to sell you a new outer tub (around $300) if you get a Neptune with bad bearings (MAH3000, MAH4000 & MAH55/65/7500) as the only way to fix it. That's why we have a way to replace the bearings ONLY without replacing the tub using factory parts. It can even be done with the tub in the washer. Drop me email and I'll give you the routine and part numbers. It's considerably cheaper for the customer and saves a good machine from untimely death. RCD |
Post# 279837 , Reply# 27   5/13/2008 at 14:08 (5,826 days old) by qsd-dan (West)   |   | |
Post# 279902 , Reply# 28   5/13/2008 at 17:06 (5,826 days old) by redcarpetdrew (Fairfield, CA)   |   | |
If you can't get a 6 digit or older Maytag part number to come up, try putting a Y in front of it. When they blended Maytag and Whirlpool part databases together, they found that there were quite a few 'shared' numbers. For example, the Maytag Drive Belt would now be a 'Y211125'. In this case, you want to pull up P/N Y0A4298. Thats a 'zero' after the Y. The additional seal works fantastic, is around $15 and ensures that the new lip sealed mounting stem won't re-offend. RCD |
Post# 279906 , Reply# 29   5/13/2008 at 17:19 (5,826 days old) by qsd-dan (West)   |   | |
Post# 279916 , Reply# 30   5/13/2008 at 17:50 (5,826 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 279924 , Reply# 31   5/13/2008 at 18:18 (5,826 days old) by qsd-dan (West)   |   | |
Is it Appliance Parts Co? I'll have to look up their new location. They pulled a fast one on me and moved last time I was up there. I'm going to have them do a few more nationwide part searches for the 63 Frigidaire washer, 58 Maytag 641C, and the 64 Maytag DE-750 (they haven't let me down yet). I think I'll top off the order with 20 of those seals. I'm hoping to be up there next week. |
