Thread Number: 17030
Maytag Agitator Compatibility |
Post# 280558   5/17/2008 at 20:26 (5,823 days old) by qsd-dan (West)   |   | |
I was wondering which of the following agitators can be directly swapped with one another. Black (assuming snap on) Turquoise (snap on) Turquoise with 1/4" side screw I may be able to get a hold of a new NOS black agitator and wanted to try it out since it is claimed to have a more effective filter design. |
Post# 280795 , Reply# 1   5/19/2008 at 19:30 (5,821 days old) by redcarpetdrew (Fairfield, CA)   |   | |
As long as the capacities are compatible, you should be able to interchange. You might have to put on a black keeper ring to hold the agitator on. I've actually put a keeper ring on with the agitators that have the set screw to snug them up... That being said, if you are trying to put a 'filter in the middle' agitator on a orbital transmission, the lint filter may not work correctly due to the quicker, shorter stroke... RCD |
Post# 280945 , Reply# 3   5/20/2008 at 18:12 (5,820 days old) by qsd-dan (West)   |   | |
Thank you very much gentleman!! It appears that I'm getting my load capacities mixed up. I'm familiar with Maytags from 1966 to 1986, but before that, things get sketchy. "You might have to put on a black keeper ring to hold the agitator on. I've actually put a keeper ring on with the agitators that have the set screw to snug them up." Great info! Do you happen to have a part # for the keeper ring? I stared at my microfiche films for nearly an hour and couldn't find any reference or part #. My large capacity turquoise agitator is beginning to develop a lot of "play" in it. I assumed it was from worn splines, which it very well could be. The keeper ring is a nice alternative to keep it going a little while longer. So, which models had the large capacity black agitators? I've never seen one in an 806. "I think the more efficient agitators you are mentioning were the original black Bakelite agitators, with a removable shroud on the bottom." Which model(s) had this agitator? I'm assuming it was used in the smaller capacity washers. Thanks in advance! |
Post# 280954 , Reply# 4   5/20/2008 at 19:11 (5,820 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 280985 , Reply# 5   5/20/2008 at 23:49 (5,819 days old) by qsd-dan (West)   |   | |
Post# 281003 , Reply# 6   5/21/2008 at 07:28 (5,819 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 281046 , Reply# 7   5/21/2008 at 12:17 (5,819 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 281059 , Reply# 8   5/21/2008 at 13:43 (5,819 days old) by pdub (Portland, Oregon)   |   | |
