Thread Number: 17236
Kitchen Aid on Craigs list |
Post# 283147 , Reply# 1   6/3/2008 at 15:44 (5,805 days old) by dadoes (TX, U.S. of A.)   |   | |
It is a 17-series Superba. Does not do assured water heating except on the Sani-Rinse option. Has a hidden rapid-advance timer, the only way to manipulate it (other than by removing the panel for physical access) is by button-pressing amongst the various cycles and using the Cancel button. An excellent machine, hampered only by the lack of an upper-rack spray arm ... which can be dealt with effectively by learning proper loading techniques.
Post# 283151 , Reply# 2   6/3/2008 at 16:12 (5,805 days old) by fltcoils (South Bend, Indiana)   |   | |
Lwr only is ok, our current 20 yr old whirlpool is lwr arm only. so the 17s are good models? -------- I've been reading and I guess the belt drive maytags are noisy, better to get a pre '75 back pump model for quiet? thanks again. |
Post# 283511 , Reply# 4   6/5/2008 at 20:15 (5,803 days old) by fltcoils (South Bend, Indiana)   |   | |
I am going to check it out. And if things are ok then great, I'll have a better dishwasher. |
