Thread Number: 17323
superba 22? |
Post# 284294 , Reply# 1   6/10/2008 at 15:12 (5,798 days old) by fltcoils (South Bend, Indiana)   |   | |
inside the tub shot |
Post# 284302 , Reply# 2   6/10/2008 at 15:59 (5,798 days old) by dadoes (TX, U.S. of A.)   |   | |
KUDS22 is a ~1992 Superba. I have one, currently being used by my sister. It's a pretty cool machine. Series 22 has touches of Whirlpool -- reversing motor -- but has heated Flo-Thru drying and a sump heater for water, new-style lower rack with plates to the side, classic 16-position upper rack with adjustable dividers. The first fill on Pots/Pans & Normal is delay-heated to 140°F. Sani Rinse heats by time, is not delayed to a specific temperature. Pots/Pans has three wash periods, heats twice in the first wash with a spray & soak period. It may heat in the 2nd wash as well, don't recall, been too long since I last used the machine. |
Post# 284356 , Reply# 3   6/10/2008 at 20:53 (5,797 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 284394 , Reply# 5   6/10/2008 at 22:31 (5,797 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 284460 , Reply# 6   6/11/2008 at 09:20 (5,797 days old) by fltcoils (South Bend, Indiana)   |   | |
Can a built-in be upgraded into a portable? That's my ultimate goal. Did they make a portable version of this '92 superba 22? Where might I find a donor portable in which I can insert this superba 22? |
Post# 284592 , Reply# 7   6/11/2008 at 22:23 (5,796 days old) by andrewinorlando ()   |   | |
Pictures of the Superba Selectra 22 are posted in separate thread. |
Post# 285567 , Reply# 10   6/16/2008 at 16:08 (5,792 days old) by fltcoils (South Bend, Indiana)   |   | |
Here is a pic of the pump etc. |
Post# 285568 , Reply# 11   6/16/2008 at 16:10 (5,792 days old) by fltcoils (South Bend, Indiana)   |   | |
and the wider view |
Post# 285594 , Reply# 12   6/16/2008 at 19:00 (5,792 days old) by johnb300m (Chicago)   |   | |
Post# 285597 , Reply# 13   6/16/2008 at 20:32 (5,791 days old) by jeffg ()   |   | |
It may not be abuse, but simply adjustments to fit tall or awkward pieces. We often bend the tines in our DW to accomodate bowls, pots and baking pans. |
Post# 285615 , Reply# 14   6/16/2008 at 22:04 (5,791 days old) by johnb300m (Chicago)   |   | |
Post# 286223 , Reply# 15   6/20/2008 at 11:33 (5,788 days old) by stopmeister72 (Irving, TX)   |   | |
Post# 288186 , Reply# 17   7/2/2008 at 01:02 (5,776 days old) by mark_usa ()   |   | |
I have KDS-18 racks. They are in very good condition. They are compatible. Hopefully Steve T will tell us the differences between KDS-18 & KDS-22 racks. Congratulations on your new machine. |
Post# 288684 , Reply# 24   7/4/2008 at 19:34 (5,773 days old) by stevet (West Melbourne, FL)   |   | |
I still have the other machines here, Andrew! |
Post# 288706 , Reply# 25   7/5/2008 at 00:24 (5,773 days old) by roto204 (Tucson, AZ)   |   | |
You're right, Steve; the 23 uses the Whirlpool mounting rails and when I went to put the rack from my 22-series Superba in the 23 I had found, I was surprised to find the rack rollers were different sizes--so I had to do a huge transplant of the rails and rollers from the 23 rack back onto my 22 rack so that I could have the nice metal wash-arm and china guard, as opposed to the plastic upper wash arm and no-china guard of the 23. The things we do :-) |
