Thread Number: 17324
maytag a106 |
Post# 284301   6/10/2008 at 15:49 (5,798 days old) by dynaflow (rockingham nc)   |   | |
Post# 284315 , Reply# 1   6/10/2008 at 16:54 (5,798 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 284338 , Reply# 2   6/10/2008 at 18:50 (5,798 days old) by ruprecht ()   |   | |
Hi, 'run' windings broken so only runs on 'start' windings? Or is the motor polling due to a worn rear motor bush? Just thought i'd throw my two bobs worth in! R |
Post# 284361 , Reply# 3   6/10/2008 at 21:08 (5,798 days old) by dynaflow (rockingham nc)   |   | |
Post# 284431 , Reply# 4   6/11/2008 at 06:32 (5,798 days old) by toggleswitch2 ()   |   | |
May already be bypassed. Doesn't explain the half-second pump-out. Can't hurt to check if all wires to motor are still connected. Does it do the same thing upon wash/agitation? (i.e. motor in reverse direction?) |
Post# 284787 , Reply# 5   6/12/2008 at 16:48 (5,796 days old) by dynaflow (rockingham nc)   |   | |
Post# 284788 , Reply# 6   6/12/2008 at 16:56 (5,796 days old) by qsd-dan (West)   |   | |
Post# 284798 , Reply# 7   6/12/2008 at 17:36 (5,796 days old) by toggleswitch2 ()   |   | |
Could the pump be locked? You'd think the belt would still turn though........ |
Post# 284803 , Reply# 8   6/12/2008 at 17:57 (5,796 days old) by dynaflow (rockingham nc)   |   | |
Post# 284804 , Reply# 9   6/12/2008 at 17:58 (5,796 days old) by dynaflow (rockingham nc)   |   | |
Post# 286283 , Reply# 10   6/20/2008 at 18:17 (5,788 days old) by dynaflow (rockingham nc)   |   | |
Post# 286287 , Reply# 11   6/20/2008 at 18:42 (5,788 days old) by qsd-dan (West)   |   | |
Post# 286295 , Reply# 12   6/20/2008 at 19:54 (5,788 days old) by dynaflow (rockingham nc)   |   | |
Post# 286468 , Reply# 13   6/21/2008 at 20:21 (5,787 days old) by dynaflow (rockingham nc)   |   | |
Post# 287225 , Reply# 14   6/25/2008 at 10:40 (5,783 days old) by dynaflow (rockingham nc)   |   | |
Post# 287235 , Reply# 15   6/25/2008 at 11:42 (5,783 days old) by qsd-dan (West)   |   | |
Oops, somehow I missed this post. I can't seem to find a switch with that number. Actually, that number doesn't even sound right. Usually it will start with a 2 (example 2-05131). Is this the original motor? If it's, I should be able to find the correct part # via microfiche. I'll be out of town through Saturday without access to the internet, so I should have a definitive answer for you by then. |
Post# 287269 , Reply# 16   6/25/2008 at 16:27 (5,783 days old) by dynaflow (rockingham nc)   |   | |
Post# 287470 , Reply# 17   6/26/2008 at 19:42 (5,782 days old) by dynaflow (rockingham nc)   |   | |
Post# 287845 , Reply# 18   6/29/2008 at 18:09 (5,779 days old) by qsd-dan (West)   |   | |
Post# 287860 , Reply# 19   6/29/2008 at 21:07 (5,779 days old) by dynaflow (rockingham nc)   |   | |
Post# 287862 , Reply# 20   6/29/2008 at 21:08 (5,779 days old) by dynaflow (rockingham nc)   |   | |
