Thread Number: 17490
Dead Dependable Care Maytag |
Post# 286454 , Reply# 2   6/21/2008 at 18:17 (5,799 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 286464 , Reply# 3   6/21/2008 at 19:14 (5,799 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 286770 , Reply# 4   6/23/2008 at 11:59 (5,797 days old) by bobbyderegis (Boston)   |   | |
Guys: It's an LAT9416AAE, serial # 22275072SU. The lid switch is clicking. Besides, wouldn't it fill with a bad lid switch? Bobby in Boston |
Post# 286841 , Reply# 5   6/23/2008 at 17:57 (5,797 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 286899 , Reply# 6   6/23/2008 at 21:33 (5,797 days old) by coldspot66 (Plymouth, Mass)   |   | |
Hi Bobby, Marcone in Malden should have the lid switch p/n 12001908. Or I can send you one. Let me know. |
Post# 286940 , Reply# 8   6/24/2008 at 06:31 (5,796 days old) by bobbyderegis (Boston)   |   | |
Sorry guys: I didn't read the above threads carefully. I'll order pt. # 12001908. Now I understand it's a one piece unit. I'll keep you posted. Bobby in Boston |
Post# 287180 , Reply# 9   6/25/2008 at 06:49 (5,795 days old) by bobbyderegis (Boston)   |   | |
OK: I got the part. Now what to do with it? Cripe, they have changed these machines so much you would think it's a Whirlpool. There are no screws. Does it just snap in? Bobby in Boston |
Post# 287232 , Reply# 10   6/25/2008 at 11:14 (5,795 days old) by redcarpetdrew (Fairfield, CA)   |   | |
You either unhook the console from the washer top or remove the timer to make it easier. Lift the lid to take pressure off the switch. There is a little plastic tab to one side of the switch that you gently lift to unlock the switch and it slides forward a little bit and comes separate from the top. Putting the new one in is as simple as engaging the ears on the switch into the top and sliding back until the lock tab engages. Good luck! RCD |
Post# 287245 , Reply# 11   6/25/2008 at 12:27 (5,795 days old) by bobbyderegis (Boston)   |   | |
Thanks RCD. I'll keep you all posted. Bobby in Boston |
