Thread Number: 18283
Cat on the Miele |
Post# 297274   8/16/2008 at 20:30 (5,731 days old) by peterh770 (Marietta, GA)   |   | |
Post# 297295 , Reply# 1   8/16/2008 at 21:01 (5,731 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 297457 , Reply# 3   8/17/2008 at 13:07 (5,731 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 297501 , Reply# 4   8/17/2008 at 16:59 (5,730 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 297622 , Reply# 5   8/18/2008 at 10:06 (5,730 days old) by peterh770 (Marietta, GA)   |   | |
Hey Eddy! Yes, it was one of the fuse holders in the electrical box (on the wall behind the basket). I think one of the fuses had blown, so all the power was going thru only one, which did not blow, and overheated too many times, warping and melting the fuse holder. A quick trip to Graingers for a replacement 15A fuse holder, and it was good. (Now the dryer side is starting to do the same, even with new fuses. Who woulda thunk a fuse holder would go bad?) Now I have to reconfig the laundry room for the W1928/T15?? set I got recently... The cat is Benita, the house punk. |
Post# 297732 , Reply# 7   8/18/2008 at 20:26 (5,729 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 297734 , Reply# 8   8/18/2008 at 20:31 (5,729 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Peter, I don't think I've seen that model of Miele. Does it have a porthole? I just got a W1930 which is identical to your 1918 only without the porthole. I have a splitter box very similar to yours... I better keep an eye on those fuses and holders inside. What's the highest temp setting on your 1918? My 1930 goes to 95 celcius which is just over 200.
Post# 297745 , Reply# 9   8/18/2008 at 21:40 (5,729 days old) by toggleswitch2 ()   |   | |
HA HA HA HA. I meant the ELECTRICAL BOX/SPLITTER! :-0) |
Post# 297764 , Reply# 10   8/18/2008 at 22:30 (5,729 days old) by peterh770 (Marietta, GA)   |   | |
The W1926 is the large capacity version of the W1918. The spin speed only goes to 1200 rpm with only 3 speed selections (1200, 900, 600)plus "without final spin". On the W1918, the extra hot temps are 150, 160 and 170. On the W1926, the extra hot temps are 155 (70), 180 (80) and 190 (90) (these f/c translations are from the owner's manual. On the W1926, the dark gray "rapid wash" indicator includes all cycles/temps except Woolens and the ala carte selections. On the W1918, "rapid wash" includes Woolens, but not the extra hot Cotton options. Just took this in the dark. Will get a better pic when the sun is up... The dryer is T1526. |
Post# 297765 , Reply# 11   8/18/2008 at 22:39 (5,729 days old) by peterh770 (Marietta, GA)   |   | |
Post# 297766 , Reply# 12   8/18/2008 at 22:40 (5,729 days old) by peterh770 (Marietta, GA)   |   | |
Post# 297778 , Reply# 13   8/18/2008 at 22:55 (5,729 days old) by eddy1210 (Burnaby BC Canada)   |   | |
That's interesting Peter, I've never seen that model in Canada at all. The 1st larger capacity 6 kg machines started here with the W1986. Here's a pic of my 1930. I hate the fact that there's no porthole but this was found still brand new in a liquidation place and I just couldn't say no. I'm guessing mine is a mid- 90's machine.
Post# 297786 , Reply# 14   8/18/2008 at 23:10 (5,729 days old) by peterh770 (Marietta, GA)   |   | |
Post# 297851 , Reply# 16   8/19/2008 at 10:12 (5,729 days old) by seamusuk (Dover Kent UK)   |   | |
Post# 297853 , Reply# 17   8/19/2008 at 10:16 (5,729 days old) by peterh770 (Marietta, GA)   |   | |
Post# 297875 , Reply# 19   8/19/2008 at 12:22 (5,729 days old) by mielabor ()   |   | |
Is there no problem with the difference in cycle frequencies (50/60 Hz)? The connector box doesn't seem to convert that. |
Post# 297936 , Reply# 20   8/19/2008 at 14:34 (5,728 days old) by eddy1210 (Burnaby BC Canada)   |   | |
