Thread Number: 18566
Finally my 59-WCI is home ! |
Post# 301226 , Reply# 2   9/3/2008 at 18:44 (5,713 days old) by tuthill ()   |   | |
Doesn't Steve Gyrafoam live in Atlanta? I'm pretty sure he'd be able to help you. NO PICS???????????? That's blasphemy. |
Post# 301233 , Reply# 3   9/3/2008 at 19:05 (5,713 days old) by rickr (.)   |   | |
Steve no longer lives in Atlanta. Congrats on your machine! You have a Multimatic and no mechanical experiance?? You may be in for some fun filled lessons! Prime the pump with hot soapy water before you do try the machine out again. The humming sound may be the motor start capacitor. The start cap is easy to replace, and only cost about $10.00 or so. The motor cap is located in the control panel in my 60, however it may be located on the side of the motor on a 59. The motor capacitor is black bakelite, and round. Two wires attach to it. If the cap is attached to the side of the motor, it will be under a protective metal shield. Be sure the power is disconnected before you try to work on your machine. Good luck, and let us know what you find. |
Post# 301545 , Reply# 4   9/5/2008 at 07:18 (5,712 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
