Thread Number: 18889
Frigidaire that spins backwards |
Post# 305927   9/26/2008 at 20:53 (5,702 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
It does not agitate but spins in both directions Something has to be busted I am not sure what it is Does something in the spin part lock so it can pulsate and keep the tub from rotating in the wash cycle CLICK HERE TO GO TO bpetersxx's LINK |
Post# 305932 , Reply# 1   9/26/2008 at 21:07 (5,702 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Post# 305950 , Reply# 2   9/26/2008 at 21:36 (5,702 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
This is likely a Rollermatic that has bad rollers. In agitate direction, the spring-mounted rollers for agitate are "drawn" to the motor hub thus transferring power to the agitate mechanism. When the motor reverses for spin, the spin roller is drawn to the hub and power is transferred to the spin mechanism. I would guess that the spin roller is stuck in position to transfer the power in both directions. There is a clutch in this mechanism, but it appears to be working OK, as is the tub brake. Check to see that all the rollers are clean and move in and out on their brackets as they were intended to. It's only slight movement, but enough to keep it from making contact with the hub. Use lighter fluid on a rag to clean the rollers and be sure all surfaces of the rollers and driven "wheels" are clean. |
Post# 305983 , Reply# 3   9/26/2008 at 22:29 (5,702 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Post# 306017 , Reply# 4   9/27/2008 at 02:50 (5,702 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 306096 , Reply# 5   9/27/2008 at 11:33 (5,701 days old) by tuthill ()   |   | |
Would the broken clutch spring be part of the motor/pulley/belt set up, or would that be the one inside the transmission? |
Post# 306155 , Reply# 6   9/27/2008 at 17:57 (5,701 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Post# 306173 , Reply# 7   9/27/2008 at 20:07 (5,701 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
We had this a few days ago about the multimatic... The machine looks like it "wants" to pulsate but can't, I wonder if there's something else inside the tranny amiss? CLICK HERE TO GO TO gansky1's LINK |
