Thread Number: 19352
New Kenmore 800 |
Post# 311677   10/26/2008 at 20:55 (5,660 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 311678 , Reply# 1   10/26/2008 at 21:05 (5,660 days old) by arrrooohhh (Sydney Australia)   |   | |
What is so interesting?? I just looked at the Whirlpool website and couldn't see anything interesting. |
Post# 311679 , Reply# 2   10/26/2008 at 21:12 (5,660 days old) by andrewinorlando ()   |   | |
Is there a link to for this one? I can't find this model on Sears website. |
Post# 311697 , Reply# 3   10/27/2008 at 02:09 (5,660 days old) by dadoes (TX, U.S. of A.)   |   | |
The 800 is not yet on Kenmore's site, I saw it in a store. Whirlpool's model is listed on their site. 1. Traditional direct-drive/tranny toploader. 2. EnergyStar qualified. 3. Automatic water level. The 800 does not have a water level control at all (no manual selection). I can't say about the Whirlpool, there isn't a close-up of the panel. 4. Triple-spray fill flume integrated into the tub ring. 5. Separate control for Softener Added Yes/No, which changes the rinse. 6. The 800 has a Bulky cycle, which is something new for a DD toploader. |
Post# 311703 , Reply# 4   10/27/2008 at 07:23 (5,659 days old) by drewz (Alexandria, Virginia)   |   | |
Other interesting items about the 2009 800 Series. -You can no longer get a porcelain lid & top on either washer or dryer in 2009. -Hardware being used (esp) knobs are of much less quality than I have ever seen in a Kenmore or Whirlpool product. -800 Series does not offer any colors, but lower end line 700 Series offers a darker blue color. -Sears/Whirlpool has also limited series to only 800,700,600, & 500, others have been dropped. |
Post# 311724 , Reply# 5   10/27/2008 at 11:04 (5,659 days old) by jasonl (Cookeville, TN)   |   | |
It's STILL a dream machine! CLICK HERE TO GO TO jasonl's LINK |
Post# 311725 , Reply# 6   10/27/2008 at 11:05 (5,659 days old) by jasonl (Cookeville, TN)   |   | |
Ain't nothing like the real thing. |
Post# 311740 , Reply# 7   10/27/2008 at 12:49 (5,659 days old) by drewz (Alexandria, Virginia)   |   | |
Post# 311792 , Reply# 8   10/27/2008 at 14:08 (5,659 days old) by kenmoreguy64 (Charlotte, NC)   |   | |
I am not particularly a DD washer fan (I do respect them and recommend them when asked by friends what they should buy), but I LOVE those pacific blue machines. We just got a Sears outlet store that is right on my way home. During it's grand opening it had about 25 of those machines all lined up, back to back. Some had five water levels, some had the infinite switch, but either way they were awesome looking. Next to them in another huddle was the matching 27-inch dryer. If they'd had a 29-inch dryer, I'd have been hard pressed not to leave with a set (not sure what I'd do with it later, but I'd have bought it!). The machines were priced well too, relatively, at less than $500. I agree with Jason whole-heartedly, nothing beats the real thing. Gordon |
Post# 312059 , Reply# 10   10/28/2008 at 19:59 (5,658 days old) by vintagesearch ()   |   | |
here it is seems cool....i wanna see the whirlpool version CLICK HERE TO GO TO vintagesearch's LINK |
Post# 312061 , Reply# 11   10/28/2008 at 20:01 (5,658 days old) by appnut (TX)   |   | |
Post# 312088 , Reply# 12   10/28/2008 at 22:47 (5,658 days old) by tuthill ()   |   | |
So how does it become energy star qualified?????????? |
Post# 312122 , Reply# 13   10/29/2008 at 07:51 (5,657 days old) by coldspot66 (Plymouth, Mass)   |   | |
Probably cooler "hot & warm" temps....option of spray rinsing instead of deep rinse, auto water level control and maybe faster spin? |
Post# 312212 , Reply# 14   10/29/2008 at 16:42 (5,657 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 313643 , Reply# 15   11/7/2008 at 13:44 (5,648 days old) by repair-man (Pittsburgh PA)   |   | |
I see that Whirlpool has the same machine in their line. And I'm sure Maytag won't be far behind. You have to give Whirlpool some points for doing what will probably be neccessary to keep toploaders alive (or should I say legal) for a little while longer. Ed |
Post# 313791 , Reply# 17   11/8/2008 at 17:16 (5,647 days old) by logixx (Germany)   |   | |
The auto load detection system on the classic washer system has a control that will sense the load in a washing machine to provide the required amount of water during fill and rinse. This control will interface with a new flow meter, the current ATC combo switch, and the timer as required during a cycle. The new control will provide consumer benefits of new energy saving water options.The auto load detection control is the Fabric Softener Switch. If “Softener Added” is selected the unit will give a full sized fill in the rinse cycle. If “No Softener Added” is selected, the rinse fill will be measured. This system will replace the current pressure switch. During the first fill, the water will enter to a low level, then agitate for 10 seconds. This is to assure that all of the clothing becomes saturated. The Load sensing control will analyze the adjusting information from the flow meter and the pressure sensor to then fill to a proper level. The second fill will fill by volume, measured by the flow meter. The Accessory Plug is a test point for the factory. All failures default to high water levels. Source: secured.whirlpool.com/Service/Sr... |
Post# 313792 , Reply# 18   11/8/2008 at 17:25 (5,647 days old) by vintagesearch ()   |   | |
how interesting, reading the tech info says if it fails to measure the water level properly it will fill to its max with water interesting..... |
Post# 313832 , Reply# 19   11/9/2008 at 05:42 (5,646 days old) by brisnat81 (Brisbane Australia)   |   | |
That must be an interesting sight at 120 strokes per minute and a full load with half a tub of water. Is there any load sensing capabilities built into the drive mechanism or it just all based on absorbtion? |
Post# 313834 , Reply# 20   11/9/2008 at 06:14 (5,646 days old) by tolivac (greenville nc)   |   | |
NEW!!!We now present the "auto load detector" KN 800 clothes CHOPPER!!A new recipe for shredded clothes-not enough water to circulate them in-so they get chopped up by the 120STM agitator!Think the system should go to lo speed if it selects lo water level. |
Post# 313896 , Reply# 22   11/9/2008 at 10:19 (5,646 days old) by chaskelljr2 (Washington, D. C.)   |   | |
You're right Jason!!!! There's NOTHING like the real thing....... That is a cool looking 1972 Model 800 you're posing with. The old one is FAR MORE attractive than the newer looking one I saw on Sears' website, if I do not say so myself. --Charles-- |
Post# 318095 , Reply# 23   12/4/2008 at 09:13 (5,621 days old) by drewz (Alexandria, Virginia)   |   | |
Over heard a conversation about New 800 Series Kenmore, Energy Star, seems that alot of people are returning them because they keep lifting the lid and doing this makes the cycle/system reset. They said people want to see if the water level is correct for the load size and when they lift the lid it resets the cycle. People are exchanging down to 700 Series that allows water levels to be chosen manually. 700 Series is currently the best seller. |
Post# 318155 , Reply# 24   12/4/2008 at 18:24 (5,621 days old) by surgilator_68 (Maryland)   |   | |
Post# 318157 , Reply# 25   12/4/2008 at 18:26 (5,621 days old) by surgilator_68 (Maryland)   |   | |
Post# 318171 , Reply# 27   12/4/2008 at 20:47 (5,621 days old) by arrrooohhh (Sydney Australia)   |   | |
Why don't they just put a window lid in this machine? Problem solved! |
Post# 318176 , Reply# 28   12/4/2008 at 21:09 (5,621 days old) by surgilator_68 (Maryland)   |   | |
Post# 318177 , Reply# 29   12/4/2008 at 21:10 (5,621 days old) by surgilator_68 (Maryland)   |   | |
