Thread Number: 20054
Maytag A206 Automatic Washer Issueş |
Post# 320594 , Reply# 1   12/20/2008 at 11:06 (5,605 days old) by jeffg ()   |   | |
Worn dogs? Check the "No agitate" section here: CLICK HERE TO GO TO jeffg's LINK |
Post# 320604 , Reply# 2   12/20/2008 at 12:06 (5,605 days old) by jwh157 ()   |   | |
The drive pulley is turning but it appears there is too much resistance to turn it in the direction for wash which is the opposite direction of spin. |
Post# 320608 , Reply# 3   12/20/2008 at 12:54 (5,605 days old) by coldspot66 (Plymouth, Mass)   |   | |
transmission issue. Either the oil in the tranny has become like varnish, or you have a busted gear that will not allow the pulley to turn easily. |
Post# 320647 , Reply# 4   12/20/2008 at 19:47 (5,605 days old) by redcarpetdrew (Fairfield, CA)   |   | |
If the washer is in good enough shape, you might consider dropping in a donor transmission. Just about any Maytag washer of the same capacity with a helical transmission will do. 06's, 08's, 10's, most 12's or their variations. I suppose you COULD drop in a orbital transmission, if you really wanted to, as well... RCD |
Post# 320729 , Reply# 5   12/21/2008 at 14:08 (5,604 days old) by qsd-dan (West)   |   | |
Post# 320857 , Reply# 7   12/22/2008 at 11:43 (5,603 days old) by redcarpetdrew (Fairfield, CA)   |   | |
