Thread Number: 21825
SEARS ROTO RACK PICS!!! |
Post# 343200 , Reply# 1   4/17/2009 at 22:26 (5,487 days old) by soberleaf ()   |   | |
rinse and dry cycle. never seen that before |
Post# 343203 , Reply# 2   4/17/2009 at 22:27 (5,487 days old) by soberleaf ()   |   | |
and control panel |
Post# 343206 , Reply# 3   4/17/2009 at 22:30 (5,487 days old) by soberleaf ()   |   | |
hides in a compartment with a tilting door on back top of dishwasher |
Post# 343207 , Reply# 4   4/17/2009 at 22:34 (5,487 days old) by soberleaf ()   |   | |
flips open |
Post# 343208 , Reply# 5   4/17/2009 at 22:36 (5,487 days old) by soberleaf ()   |   | |
after tearing it all out |
Post# 343209 , Reply# 6   4/17/2009 at 22:37 (5,487 days old) by soberleaf ()   |   | |
another |
Post# 343211 , Reply# 7   4/17/2009 at 22:39 (5,487 days old) by soberleaf ()   |   | |
it's one of my favorite designs!!! love listening to it spin during wash as they usually squeak a bit as they turn. |
Post# 343212 , Reply# 8   4/17/2009 at 22:41 (5,487 days old) by soberleaf ()   |   | |
another. note wash tube in back is missing the supply tube that runs up the back wall of the tub and feeds it. |
Post# 343213 , Reply# 9   4/17/2009 at 22:42 (5,487 days old) by soberleaf ()   |   | |
i had to remove it as it is broken. missing a good chunk. |
Post# 343214 , Reply# 10   4/17/2009 at 22:43 (5,487 days old) by soberleaf ()   |   | |
view of it |
Post# 343215 , Reply# 11   4/17/2009 at 22:46 (5,487 days old) by soberleaf ()   |   | |
pic of it. i will try to buy a new one but if they are not available i will improvise with pvc pipe probably, or a hose. all in all i'm not worried about it. |
Post# 343216 , Reply# 12   4/17/2009 at 22:47 (5,487 days old) by soberleaf ()   |   | |
is also broken but a new one will come with the seal kit. i could prob still use this one if i had to. |
Post# 343217 , Reply# 13   4/17/2009 at 22:48 (5,487 days old) by soberleaf ()   |   | |
is fine |
Post# 343219 , Reply# 14   4/17/2009 at 22:50 (5,487 days old) by soberleaf ()   |   | |
will be replaced. if i can't get a new one i will make my own. you can buy rubber to make them at auto parts stores or home depot. |
Post# 343220 , Reply# 15   4/17/2009 at 22:51 (5,487 days old) by soberleaf ()   |   | |
on display |
Post# 343222 , Reply# 17   4/17/2009 at 22:55 (5,487 days old) by soberleaf ()   |   | |
has some pretty good rust at the back, any suggestions as to what to coat it with? |
Post# 343224 , Reply# 18   4/17/2009 at 22:57 (5,487 days old) by soberleaf ()   |   | |
is dirty and the sump looks all rusted, but it is very light actually. a lot of rust stains but the metal itself is still quite good! |
Post# 343225 , Reply# 19   4/17/2009 at 22:59 (5,487 days old) by soberleaf ()   |   | |
better view. i'm going to clean it up and wire brush the rust and paint it with rustoleum primer and then a couple coats of rustoleum paint. that should do the trick. |
Post# 343229 , Reply# 21   4/17/2009 at 23:17 (5,487 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Post# 343232 , Reply# 23   4/17/2009 at 23:34 (5,487 days old) by soberleaf ()   |   | |
bottom panel off. rusted areas are gonna be painted but all in all the rust is very light. |
Post# 343233 , Reply# 24   4/17/2009 at 23:36 (5,487 days old) by soberleaf ()   |   | |
of pump sump not that bad, a little rustoleum primer and paint will do wonders |
Post# 343235 , Reply# 25   4/17/2009 at 23:37 (5,487 days old) by soberleaf ()   |   | |
view |
Post# 343236 , Reply# 26   4/17/2009 at 23:38 (5,487 days old) by soberleaf ()   |   | |
has a heater fan to circulate the drying heat |
Post# 343237 , Reply# 27   4/17/2009 at 23:40 (5,487 days old) by soberleaf ()   |   | |
but what the heck! it's prob 35 years old! and a wire brush on the drill will really help. |
Post# 343238 , Reply# 28   4/17/2009 at 23:41 (5,487 days old) by soberleaf ()   |   | |
and drain pump |
Post# 343239 , Reply# 29   4/17/2009 at 23:42 (5,487 days old) by soberleaf ()   |   | |
showing drain impeller that as yet i cannot remove! seal is underneath this impeller ofcourse. |
Post# 343245 , Reply# 32   4/18/2009 at 00:50 (5,487 days old) by peteski50 (New York)   |   | |
Post# 343249 , Reply# 34   4/18/2009 at 01:17 (5,487 days old) by soberleaf ()   |   | |
any appliance that came out after around 1979!!! and the brand new stuff! don't get me started on that! if i could push a button and return to the 50, 60's, or 70's i would be gone tomorrow! |
Post# 343310 , Reply# 38   4/18/2009 at 12:03 (5,486 days old) by appnut (TX)   |   | |
Nice to see. My aunt used Rinse&Dry on her LK because she insed everything before loading lol. I think we used it a couple of times to wash dusty things. Someone pushed all the tines in the top rack to toward the center, I can't imagine why. But that really messes up the loading pattern up there with them tilted so much. They should be standing up straight.
