Thread Number: 21860
Kitchenaide help |
Post# 343674 , Reply# 1   4/20/2009 at 10:25 (5,485 days old) by gyrafoam (Wytheville, VA)   |   | |
send Combo52 an e-mail. He will know exactly what to do. Best wishes! |
Post# 343842 , Reply# 2   4/20/2009 at 23:28 (5,484 days old) by soberleaf ()   |   | |
get ahold of stevet! |
Post# 344109 , Reply# 5   4/22/2009 at 10:16 (5,483 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Do you mean the wash-arm has four 'spokes' - called the 4 - Way Hydrosweep Wash Arm? The impeller(s) are inside the pump, not visible without disassembly. The very old dishwashers from other makers had impeller washing action - a small spiral or metal fan-shaped device in the bottom of the tank to disperse the water. KitchenAid never used an impeller for their dishwashers - only wash arms and in fact, most impellers were completely gone by the early 60's, I think Westinghouse was the last to use this style of washing. Good luck with your repair! |
Post# 344289 , Reply# 8   4/23/2009 at 08:54 (5,482 days old) by lesto (Atlanta)   |   | |
Thanks for all the help, Steve. I've checked my plumbignand everything is clear so the problem must be somewhere in or near the pump so I'll take a crack at it this weekend. If you don't mind I'd love a scan of the breakdown. Thanks, Les |
Post# 344789 , Reply# 10   4/25/2009 at 21:04 (5,479 days old) by stevet (West Melbourne, FL)   |   | |
Les, I am emailing you a scan of the pump breakdown and repair procedures for your review!. any questions, please let me know Steve |
Post# 345052 , Reply# 12   4/27/2009 at 10:01 (5,478 days old) by coldspot66 (Plymouth, Mass)   |   | |
If it has the W/P pump module, disconnect the drain hose at the pump and unscrew the drain valve extension. Small round objects will block the flow of drain water, as it is a smallish opening. That may be your only problem. Try it before disassembling the motor/pump. |
Post# 345053 , Reply# 13   4/27/2009 at 10:04 (5,478 days old) by coldspot66 (Plymouth, Mass)   |   | |
oops, disregard my previous post. It is NOT the W/P style pump module, if it's a "21". check the blue drain/check valve for an obstuction before you tear into the pump. |
Post# 345130 , Reply# 16   4/27/2009 at 17:29 (5,478 days old) by stevet (West Melbourne, FL)   |   | |
Les, I resent the file to the address you gave above but I am not sure it was a valid email address. Is it? My outlook express burped a bit on me when I typed it in. Steve |
Post# 345233 , Reply# 17   4/28/2009 at 06:45 (5,477 days old) by lesto (Atlanta)   |   | |
Hi Steve, I got your email just fine. I'll let you know what i find. Les |
