Thread Number: 22127
Maytag Questions |
Post# 346849 , Reply# 1   5/5/2009 at 21:46 (5,469 days old) by lebron (Minnesota)   |   | |
Post# 346859 , Reply# 3   5/5/2009 at 22:15 (5,469 days old) by qsd-dan (West)   |   | |
"I have replaced the outer tub clamp how tight do you tighten the bots on the clamp?" I grab the biggest screw driver I have and crank them down as tight as I can. I don't think it's humanly possible to damage the tub cover or outer tub. "I've also replaced the belts, but now when the washer spins it squeals, at the beginning of the spin cycle." Did you purchase genuine Maytag belts? The ones you posted in another thread were NOT genuine Maytag belts. Did you clean both motor pulley grooves? Also, I have yet to get Maytag that didn't need a spring/glide replacement and lube (Part# 205000) along with a good cleaning of the sliding carriage. A rare possibility, but no so uncommon if genuine Maytag belts are NOT used, is improper pump pulley tension. Should be 1/4 inch between the pump belt if gently squeezed in the middle. |
Post# 346876 , Reply# 5   5/5/2009 at 23:16 (5,469 days old) by qsd-dan (West)   |   | |
Post# 346922 , Reply# 6   5/6/2009 at 07:26 (5,469 days old) by yogitunes (New Jersey)   |   | |
I use to work in a laundry with maytag top loaders, the chemicals we used use to damage the pumps and they would start to squeal during first start of spin...once we replaced them the noise would stop....with so many machines running was hard to tell which one was making the noise...once replaced all was quiet....could solve your problem maybe...funny though they only squealed during spin never during wash action...go figure
