Thread Number: 22149
Maytag repair information needed |
Post# 347094 , Reply# 1   5/6/2009 at 17:41 (5,468 days old) by yogitunes (New Jersey)   |   | |
sounds like the timer...does it move during a "time only" cycle...simple to replace...you may be able to get just the little motor that makes it turn...otherwise you're talking complete timer replacement... I had that on one dryer...you could turn it on and off by the timer knob but it would not turn to off by itself...would run for hours...once replaced...runs like normal |
Post# 347095 , Reply# 2   5/6/2009 at 18:03 (5,468 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 347097 , Reply# 4   5/6/2009 at 18:22 (5,468 days old) by qsd-dan (West)   |   | |
The most common failure is the capacitor mounted to the control board, which is "saturated" by the amount of moisture the baffles detect. Electrolytic capacitors start going south after 20 years. I'm pretty sure the capacitor is available separately, but you may end up having to buy the whole shebang. Unfortunately, the douche-bag previous owner of my microfiche slides burned up this particular slide and it's pretty much unreadable. Sorry.
Post# 347098 , Reply# 5   5/6/2009 at 18:25 (5,468 days old) by qsd-dan (West)   |   | |
"but I've read often on the site that the Electronic Maytag Dryers especially by brand, need to have a Ground Wire connected to the Cabinet, to allow the Control to operate properly." Eh, I run my DE750 and DE806 from a home made 220 extension cord with no earth ground wire attached to either machine. No drying issues. |
Post# 347115 , Reply# 6   5/6/2009 at 19:14 (5,468 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The electronic contol units of that time had a solenoid that used a paperclip like linkage (p/n 312260) to move a slide in the electronic control switch. I've seen that wire break which stops the solenoid from shutting off the control. This is common. There is also a test board used to test the electronic control system itself. RCD |
