Thread Number: 22250
Kenmore Elect Dryer Model #84082 |
Post# 348459 , Reply# 1   5/12/2009 at 20:45 (5,462 days old) by yogitunes (New Jersey)   |   | |
Post# 348498 , Reply# 2   5/12/2009 at 22:05 (5,462 days old) by toggleswitch2 ()   |   | |
by heater relay so you mean the centrifugal safety switch in the motor?... Unless the motor is turning ("run" winding) the heater won't heat. |
Post# 348506 , Reply# 3   5/12/2009 at 22:12 (5,462 days old) by coldspot66 (Plymouth, Mass)   |   | |
Make sure you have 220 volts at the receptacle, and at the terminal block of the dryer. Frigidaire dryers tend to cook the heater wires when there is a heat build-up due to poor/clogged venting. |
Post# 348719 , Reply# 4   5/13/2009 at 19:29 (5,461 days old) by stefank ()   |   | |
Where was your heater relay? In the circuit board? |
