Thread Number: 22386
Maytag,loyal and true |
Post# 350443   5/20/2009 at 21:57 (5,469 days old) by laundromat (Hilo, Hawaii)   |   | |
I went to my local dump yesterday and found what looked like an older Maytag on its last leg.I brought it home and,today,I hooked it up.The fron panel clips were gone and the original or previous owner had taped it on.I removed the bolts and looked inside.The base plate was rusted but,no grease on the walls.I turned it on and the drain hose had cracks in it and it popped off the pump causing a small flood.After that and splicing/reconnecting the drain hose,I turned it back on.I forgot to mention that I also replaced the belts prior to hook up.It does fabulous!!No noise other than the strain during the spin.Once the rpms reached their climax,the noise went from a growel to a purr.It is model# A408---serial#421370YQ.The delicate and p/press buttons,when pressed do not work.It is only agitating and spinning on regular.everything else works great.Any clue on why the delicate speed for pp and del.doesn't work????Any and all help is greatly appreciated.This model will be my first collectable found on the "Big Island"!!Aloha and Mahalo!!
Post# 350480 , Reply# 1   5/21/2009 at 01:08 (5,468 days old) by qsd-dan (West)   |   | |
Post# 350487 , Reply# 2   5/21/2009 at 01:22 (5,468 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 350490 , Reply# 3   5/21/2009 at 01:45 (5,468 days old) by laundromat (Hilo, Hawaii)   |   | |
It runs like a champ.No more leaks and I have an extra base off another unit that was similar to a dead squirel after a few days out on the highway. However,the vultures had taken what they needed or wanted and left a carcuss with nothing but the base and frame off an A606 in white.Anyway,I switched them and had to also get the clamps off a Kenmore dryer that was there yesterday.They worked.I just could not believe the rat nest that was in the control panel.I need to check the unit with the wires for the lid switch connected so the lid could be completely open during its test drive.I know there is another way using cardboard in the back of the lid.I just prefer to use the wire method. I usualy wind up splicing them anyway. All the loads came out great and the spray rinse lasts forever!That may thoroughly rinse the close before there deeper rinse with softner but,to me,that's just a waste. Being that as it may,the clothes were dried in a gas dryer and I was quite impressed to say the least.I will now repaint the body and try to find out if the switch is bad ,a wire is loose or the motor is faulty. I don't think (and I could be wrong)that the motor is the issue. It really is a strong agitation and spin.The pump out really works well too.Lots of fun to watch. |
Post# 350501 , Reply# 4   5/21/2009 at 03:48 (5,468 days old) by maytagmike (Burlington, Vt)   |   | |
Post# 350502 , Reply# 5   5/21/2009 at 03:51 (5,468 days old) by maytagmike (Burlington, Vt)   |   | |
Post# 350504 , Reply# 6   5/21/2009 at 03:51 (5,468 days old) by maytagmike (Burlington, Vt)   |   | |
Post# 350567 , Reply# 7   5/21/2009 at 10:10 (5,468 days old) by autowasherfreak ()   |   | |
The were built to last back then, not not like today where built to last means five or 6 years. I'm glad you were able to save it. |
Post# 350572 , Reply# 8   5/21/2009 at 10:18 (5,468 days old) by charbee ()   |   | |
Congrats! I'll never forget draggin' our "Maude" (A407 got for $20!) home, tipping her back and making sure the belts were good, and then watchin' her do her glorious Maytag thing without so much as a whimper! |
Post# 350596 , Reply# 9   5/21/2009 at 11:46 (5,468 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 350601 , Reply# 10   5/21/2009 at 12:01 (5,468 days old) by maytagbear (N.E. Ohio)   |   | |
That's what a Fabric-Matic DOES! :) Instead of a true slower speed, the programmed-in pauses ensure (pretty) gentle handling of the clothes. Great catch anyway. Lawrence/Maytagbear |
Post# 350642 , Reply# 11   5/21/2009 at 14:24 (5,468 days old) by qsd-dan (West)   |   | |
Post# 350670 , Reply# 12   5/21/2009 at 16:41 (5,468 days old) by maytagmike (Burlington, Vt)   |   | |
Post# 350680 , Reply# 13   5/21/2009 at 17:28 (5,468 days old) by laundromat (Hilo, Hawaii)   |   | |
I did a huge load from the "Theater Room" where there's a 9 ft by 12 ft movie screen and a projection T.V with satalite and surround sound.Lots to eat and drink as well as plenty of 420. Anyway,I washed 8 bath towels and a set of queen size sheets with two pillow cases to boot.It did a great job and made little noise doing it.I used Gain with Bleach liquid laundry detergent and Gain fabric softner. I only use 1/4 capful of the softner. Just enough to keep the static down in the dryer and make the sheets smell nice for the next guest.I sourt of feel like I am in Zen!! LOL |
Post# 350826 , Reply# 14   5/22/2009 at 17:58 (5,467 days old) by laundromat (Hilo, Hawaii)   |   | |
