Thread Number: 2239
ATTENTION !Norge fans..... |
Post# 68518   5/28/2005 at 16:21 (6,921 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68519 , Reply# 1   5/28/2005 at 16:24 (6,921 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68520 , Reply# 2   5/28/2005 at 16:25 (6,921 days old) by appnut (TX)   |   | |
Post# 68521 , Reply# 3   5/28/2005 at 16:28 (6,921 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68522 , Reply# 4   5/28/2005 at 16:32 (6,921 days old) by PeteK (Ontari ari ari O )   |   | |
Post# 68525 , Reply# 6   5/28/2005 at 17:57 (6,921 days old) by agiflow ()   |   | |
By the way Goatfarmer, nice machine. Is this a Borg-Warner washer? |
Post# 68529 , Reply# 7   5/28/2005 at 18:35 (6,921 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68531 , Reply# 8   5/28/2005 at 18:55 (6,921 days old) by agiflow ()   |   | |
That's the next town over from me. |
Post# 68532 , Reply# 9   5/28/2005 at 18:56 (6,921 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68533 , Reply# 10   5/28/2005 at 19:00 (6,921 days old) by agiflow ()   |   | |
I believe Fedders used to produce A/C's in NJ also. |
Post# 68534 , Reply# 11   5/28/2005 at 19:49 (6,921 days old) by appnut (TX)   |   | |
Yes VHQ meant Very High Quality. This is the first time I've seen a good inside photo of one of these washers that's still the old design (filter stream and water entering on the left (vs. burp-up & water entering where this filter stream comes in). I"m so used to the big ol' bakelite black agitator of our Norge15 Dispensomat, which have very large fins at the bottom and it splashed a helluva lot on ex-lo water level and any water level below mediu, pretty much sloshed the clothes back and forth with not a lot of turnover, unless it was a very small load. So, due to my rambling, but, I still think the small fins at the bottom managed to cause quite a bit of turbulence which washed the smaller loads very well. And the large loads got movedf with that intense, big arc agitation with those large fins towawrd the top. Kenny, can I see a photo of the rest of the control panel? THanks, Bob |
Post# 68537 , Reply# 13   5/28/2005 at 20:55 (6,920 days old) by appnut (TX)   |   | |
Post# 68574 , Reply# 14   5/29/2005 at 10:44 (6,920 days old) by toggleswitch (New York City, NY)   |   | |
Mom had a similar machine in 73/74 with 8 or 9 pre-programmed settings/cycles that adjused water temp and speeds. I liked the agitator, in that the bottom vanes created enough turbulence to get up most of the way. Then the larger fins at the top would make/create more turbulence where the bottom fins would not reach. It had a nice long stroke and a speed that was neither too fast nor too slow. (giggle) They really were nice machines. The one I knew died of an oil leak too!! |
Post# 68577 , Reply# 15   5/29/2005 at 11:57 (6,920 days old) by agiflow ()   |   | |
The timer on our Norge went bad and would continually go through the cycles without shutting off. It was my mom's favorite machine. |
Post# 68596 , Reply# 16   5/29/2005 at 16:55 (6,920 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 68623 , Reply# 18   5/29/2005 at 23:47 (6,919 days old) by kenmore1978 ()   |   | |
"The sweeps on the agitator were long if I remember right." 210 degrees, something they touted in their advertising |
Post# 68639 , Reply# 20   5/30/2005 at 06:48 (6,919 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68645 , Reply# 21   5/30/2005 at 07:41 (6,919 days old) by toggleswitch (New York City, NY)   |   | |
I just LOVE SS. That timer dial rocks my world! What are the two cycles, can't quite make it out. Mom's had a regular and a pre-wash cycle. As as I said earlier, the speeds were controlled by the pre-programmed buttons. Pre-wash ==> Fill-wash-drain-spin Other than the huge "CLUNKS" of the spin solenoid engaging, it was a good machine. Mechanically it resemtbed a Maytag to the point that I believe the drive-belt was also below/underneath the base. |
Post# 68657 , Reply# 22   5/30/2005 at 12:29 (6,919 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68688 , Reply# 23   5/30/2005 at 21:22 (6,918 days old) by toggleswitch (New York City, NY)   |   | |
Post# 68905 , Reply# 25   6/1/2005 at 08:33 (6,917 days old) by agiflow ()   |   | |
I never knew Norge made machines with lid locks. Anybody know what years Norge made lid locks on their washers? |
Post# 68935 , Reply# 26   6/1/2005 at 16:30 (6,917 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 68960 , Reply# 27   6/1/2005 at 21:42 (6,916 days old) by laundramatt (Youngstown, Ohio)   |   | |
Lid lock only worked on spin and suds return cycles. |
Post# 68980 , Reply# 28   6/2/2005 at 00:22 (6,916 days old) by kenmore1978 ()   |   | |
SQ had them |
