Thread Number: 22523
MODERN MAID IMPELLER ROTO RACK DISHWASHER PICS |
Post# 352792 , Reply# 1   5/28/2009 at 18:05 (5,447 days old) by soberleaf ()   |   | |
tub is in equally fine shape for it's age! |
Post# 352793 , Reply# 2   5/28/2009 at 18:07 (5,447 days old) by soberleaf ()   |   | |
so if anyone has any info on where i could buy an impeller please let me know. i would greatly appreciate it |
Post# 352795 , Reply# 3   5/28/2009 at 18:08 (5,447 days old) by soberleaf ()   |   | |
bottom view |
Post# 352798 , Reply# 6   5/28/2009 at 18:15 (5,447 days old) by soberleaf ()   |   | |
the tube tube is in good shape and seal is also |
Post# 352799 , Reply# 7   5/28/2009 at 18:20 (5,447 days old) by soberleaf ()   |   | |
is still very soft and pliable for it's age. the other rubber ring at the bottom of the tube is also |
Post# 352800 , Reply# 8   5/28/2009 at 18:24 (5,447 days old) by soberleaf ()   |   | |
all stripped down. note the unusually large detergent cup it is operated mechanically from the timer by a cam i will show pics of this when i put timer back on. |
Post# 352804 , Reply# 10   5/28/2009 at 18:30 (5,447 days old) by soberleaf ()   |   | |
all clean again. well as clean as it will get that small hose coming out of it's side connects to a water pressure switch. |
Post# 352805 , Reply# 11   5/28/2009 at 18:31 (5,447 days old) by soberleaf ()   |   | |
of it with timer in background. timer works fine. |
Post# 352806 , Reply# 12   5/28/2009 at 18:33 (5,447 days old) by soberleaf ()   |   | |
of this rubber connector. i must have a "rubber" fetish! |
Post# 352808 , Reply# 13   5/28/2009 at 18:35 (5,447 days old) by soberleaf ()   |   | |
a large rubber vent like device. it was equally dirty but cleaned up well |
Post# 352812 , Reply# 15   5/28/2009 at 18:41 (5,447 days old) by soberleaf ()   |   | |
very easy to take motor out. |
Post# 352813 , Reply# 16   5/28/2009 at 18:44 (5,447 days old) by soberleaf ()   |   | |
in great shape, runs very quiet. it's a 1/3 h.p. 1725 rpm. gave it a good oiling at both ends (we like that). let it run awhile and it stayed nice and cool. |
Post# 352815 , Reply# 17   5/28/2009 at 18:45 (5,447 days old) by soberleaf ()   |   | |
extended shaft that screws onto main motor shaft |
Post# 352819 , Reply# 20   5/28/2009 at 18:53 (5,447 days old) by soberleaf ()   |   | |
attached to the fill valve |
Post# 352820 , Reply# 21   5/28/2009 at 18:55 (5,447 days old) by soberleaf ()   |   | |
old metal fill valve! i have already taken off it's solonoid in this pic |
Post# 352821 , Reply# 22   5/28/2009 at 18:56 (5,447 days old) by soberleaf ()   |   | |
and all seems well |
Post# 352822 , Reply# 23   5/28/2009 at 18:58 (5,447 days old) by soberleaf ()   |   | |
glued to the lower front panel. |
Post# 352838 , Reply# 25   5/28/2009 at 20:28 (5,446 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 352866 , Reply# 27   5/28/2009 at 22:28 (5,446 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Post# 352986 , Reply# 28   5/29/2009 at 09:42 (5,446 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Pete, It is great to watch you do what I never had time to do. These dishwashers were waiting patiently for you to rescue them. Super job. That impeller machine is impressive. And I like the product placement for the Zoom Spout turbine oil, great stuff. Larry at Modern is very well stocked, but you seem to have a knack for finding parts. OOOHHH, what's next? The Slant Front GMFR TL? The stainless steel KDI 16? The avocado portable? I really enjoy your posts. Oh, and I'm picking something up today that will rev your engine, I'll send pics later. I think your handle should be "DishwasherKing" matt |
Post# 352993 , Reply# 30   5/29/2009 at 10:11 (5,446 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 352994 , Reply# 31   5/29/2009 at 10:12 (5,446 days old) by turquoisedude (.)   |   | |
Post# 353004 , Reply# 32   5/29/2009 at 10:58 (5,446 days old) by soberleaf ()   |   | |
as you prob have already seen from my seperate orgasmic post! think i will change my name from "soberleaf" to "dishwasher drunk"! as it definately is an addiction! this addiction is ok however! |
Post# 353021 , Reply# 33   5/29/2009 at 12:07 (5,446 days old) by turquoisedude (.)   |   | |
