Thread Number: 23190
How to adjust water level on Frigidaire Gallery Front Loaders |
Post# 361919 , Reply# 1   7/5/2009 at 17:10 (5,408 days old) by tristarcxl ()   |   | |
After you get the top off, the pressure switch is mounted to a cross brace in the top of the cabinet. You can see it hanging here directly in back of the timer dial. |
Post# 361920 , Reply# 2   7/5/2009 at 17:11 (5,408 days old) by appnut (TX)   |   | |
Post# 361924 , Reply# 5   7/5/2009 at 17:14 (5,408 days old) by appnut (TX)   |   | |
Post# 361926 , Reply# 6   7/5/2009 at 17:16 (5,408 days old) by tristarcxl ()   |   | |
If you start a heavy or "Normal" cycle on mine it tumbles during fill with the timer running. I haven't modified mine, it came that way from the factory. |
Post# 361945 , Reply# 8   7/5/2009 at 18:02 (5,408 days old) by yogitunes (New Jersey)   |   | |
Post# 362007 , Reply# 9   7/6/2009 at 00:12 (5,408 days old) by alr2903 (TN)   |   | |
Good for you i bet it certainly rinses better with with extra water. alr2903 |
Post# 362452 , Reply# 10   7/7/2009 at 18:27 (5,406 days old) by bobbyderegis (Boston)   |   | |
What will this do to the bearing? Aren't the bearings weak links in these machines? Bobby in Boston |
Post# 362466 , Reply# 11   7/7/2009 at 19:37 (5,406 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 362487 , Reply# 12   7/7/2009 at 20:33 (5,406 days old) by gyrafoam (Wytheville, VA)   |   | |
I believe you are correct. I have a '97 built machine that has proven tough as nails, but I haven't adjusted the water level up either. Still, its nice to know how to do it. |
Post# 362501 , Reply# 13   7/7/2009 at 21:52 (5,406 days old) by jakeseacrest (Massachusetts)   |   | |
Post# 362507 , Reply# 14   7/7/2009 at 22:23 (5,406 days old) by yogitunes (New Jersey)   |   | |
I had mine for 10 years and adjusted the water level when I got it, no bearing problems, actually never a problem from the set, last year when I got the new ones I gave the old one to a niece and it still running, just wish the new ones are adjustable.... I also have come across ones with bad bearings from a factory set water level....go figure! |
Post# 362556 , Reply# 15   7/8/2009 at 08:25 (5,405 days old) by brastemp (Brazil)   |   | |
That's really cool. I really like to adjust my Frigidaire Affinity. Can you help me? |
Post# 362626 , Reply# 17   7/8/2009 at 14:35 (5,405 days old) by yogitunes (New Jersey)   |   | |
Post# 362679 , Reply# 19   7/8/2009 at 19:06 (5,405 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
martin, the hose should be very flexible and elastic. like those very flexible yellow or blue rubber hoses (i don't know how they are called in English) used when a nurse needs to give an IV injection. The idea is to make the hose expand to the sides before the pressure switch detect the pressure. |
Post# 362722 , Reply# 20   7/8/2009 at 23:22 (5,405 days old) by yogitunes (New Jersey)   |   | |
I might have something out in the garage, I have a lot of hooses on spools, maybe like hoses used for windshield washer fluid....My first attempt was using air line hose from an aquarium, but you may be right witha rubber hose that would expand a little easier......give me a few days to try out a few things and I'll get back to you on the results..... this may actually work! |
Post# 362776 , Reply# 22   7/9/2009 at 08:41 (5,404 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
1 inch won't kill your machine, but 2 inches will. The problem is when a top loader lover has to have a front loader and then adjust the water lever to almost reach the ceiling of the laundry room. |
Post# 362788 , Reply# 24   7/9/2009 at 10:26 (5,404 days old) by yogitunes (New Jersey)   |   | |
Post# 362951 , Reply# 25   7/10/2009 at 11:43 (5,403 days old) by mrb627 (Buford, GA)   |   | |
Post# 362956 , Reply# 26   7/10/2009 at 12:16 (5,403 days old) by yogitunes (New Jersey)   |   | |
