Thread Number: 23360
HOOVER NEW WAVE PROBLEM |
Post# 364146 , Reply# 1   7/15/2009 at 11:03 (5,398 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 364147 , Reply# 2   7/15/2009 at 11:03 (5,398 days old) by mark1973 ()   |   | |
Well that's my theory buggered! Just put a replacement double cold valve on and selected rinse. It filled for about 5 seconds then "Ping" Electrics off again. |
Post# 364151 , Reply# 3   7/15/2009 at 11:06 (5,398 days old) by mark1973 ()   |   | |
Hey Mike Thanks for that. The other leaks were a while back so the electrics and cabinet are dry. No water anywere else. Could be anumber of things I guess..Maybe the control board? Mark x |
Post# 364170 , Reply# 4   7/15/2009 at 11:29 (5,398 days old) by dyson2drums (United Kingdom)   |   | |
Post# 364200 , Reply# 5   7/15/2009 at 12:28 (5,398 days old) by zodawash (Lincolnshire,United Kingdom)   |   | |
It really could be any number of componants causing it to trip but inspect the wiring for any that might have worn through and touch the cabinet or metal componants. I had a tripping problem on an old Servis and after careful examination of the wiring there was a tiny bit of insulation worn away on a wire going to the cold fill valve that touched the cabinet and tripped the power. Also check the heating element. Good luck. Steve |
Post# 364222 , Reply# 8   7/15/2009 at 13:54 (5,398 days old) by bertrum ()   |   | |
the pressure switch normally shares a neutral feed with the heating element, try disconnecting the 3 element terminals and testing again. Just an idea. . . |
Post# 366001 , Reply# 18   7/21/2009 at 17:58 (5,392 days old) by electradeluxe (Blackpool, Lancs)   |   | |
we had a new wave 1100,we bought it in 1995 and it run for ten years without a problem,then the computer panel went so we had to buy a new one,it was a brilliant machine!! |
Post# 366300 , Reply# 19   7/22/2009 at 17:01 (5,391 days old) by newwave1 (Lincoln, United Kingdom)   |   | |
As the username would imply, i've been a fan of hoover newwaves for along time. I've had 2 of them now! They were innovative and washed and rinsed very well. Its a shame you've had problems with this one mark. Prehaps you will find another!! My zanussi fj1033 had a similar problem, drippin water was leaking onto the motor i think, i had a twiddle around and thought i'd fixed it and water sprayed all over the inside of the cabinet. So i gave up. Darren |
