Thread Number: 23398
paint |
Post# 364622   7/16/2009 at 16:57 (5,397 days old) by oldappliancenut ()   |   | |
what kind of paint to use on the inner tub of a washer???John sez marine paint any other ideas??? |
Post# 364628 , Reply# 1   7/16/2009 at 17:42 (5,397 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 364630 , Reply# 2   7/16/2009 at 18:00 (5,397 days old) by joelippard (Hickory)   |   | |
Post# 364647 , Reply# 3   7/16/2009 at 19:59 (5,397 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I had a Frigidaire wash/spin tub sandblasted and painted it with POR-15, in silver of course, and it turned out beautiful. It was a dreadful rusty mess from the South Dakota Farm (all the Frigidaire tubs were destroyed from the elements out there) so I drilled out the balance ring and removed the metal shavings and then had it sandblasted. I filled the balance ring with cement mix for ballast after it was done. For your drain-tub, Brian, it looks like you have a good start. You can fill the holes with a little JB-Weld or silicone as long as you cover all areas of the hole so no moisture can get to the rusty areas and continue it's destructive evil. POR-15 is made to paint over rust (P.O.R.) so it will not adhere to anything with gloss such as porcelain, etc. It should be bare (or primed) metal or rusty metal for it to work properly. I've touched up a few rusty spots on a porcelain outer tub before and had tiny bits of paint in the drain-water for months afterward. The only place it stuck was onto the tiny rusty spots, the rest just washes away. Here is the '59 Frigidaire spin-tub - ain't she pretty? ;-) |
Post# 364667 , Reply# 4   7/16/2009 at 21:39 (5,397 days old) by oldappliancenut ()   |   | |
thanks |
Post# 364756 , Reply# 5   7/17/2009 at 05:38 (5,396 days old) by gyrafoam (Wytheville, VA)   |   | |
but you could also use some rustoleum spray paint. Has worked just fine for me in the repair of minor issues such as those in the outer tub. |
Post# 364858 , Reply# 6   7/17/2009 at 13:28 (5,396 days old) by pdub (Portland, Oregon)   |   | |
Post# 364900 , Reply# 7   7/17/2009 at 15:51 (5,396 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 364926 , Reply# 8   7/17/2009 at 16:57 (5,396 days old) by pdub (Portland, Oregon)   |   | |
