Thread Number: 24056
Maytag dryer comparison |
Post# 374005 , Reply# 1   8/23/2009 at 11:50 (5,360 days old) by appliguy (Oakton Va.)   |   | |
Post# 374010 , Reply# 2   8/23/2009 at 12:24 (5,360 days old) by appnut (TX)   |   | |
I may need to see a picture of the control panel of your 407. But, if memory serves me right, the 407 has auto dry (which is exhaust temp thermostatic temp. drying) and the 806 is electronic dry control and your 407 does not have the electronic sensors in the tub. (I'm interpreting your request because you want to switch out control panels???) If I misinterpreted, I apologize--that you want to physically switch out the two dryers. Secondly, there is kind of a built-in adjustable dryness on those old electronic control dryers (before they put more dry and normal dry on panel buttons next to the high & delicate heat buttons). The permanent press dry cycle dries the load to a more dry state than the regular dry cycle. The manual states to use the perm press/wash&wear dry cycle for loads the user wants a more dry situation. Also, if the 806 does not have regualr and delicate (or something like that) dry heat temp buttons, then the dryer uses an all-fabric dry temp., which I think is the low-heat setting.
Post# 374014 , Reply# 3   8/23/2009 at 12:39 (5,360 days old) by goatfarmer (South Bend, home of Champions)   |   | |
I always say, is it ain't broke, don't fix it. They are both reliable, maybe the 407 a bit more, since it doesn't have electronic drying control. If it were me, I'd stay with the 407, unless you wanted a lighted console, or were looking to make a matching pair. My advice is given freely, value accordingly. kennyGF |
