Thread Number: 24120
For Sale - Early Whirlpool and Westinghouse Washers
Post# 374902   8/26/2009 at 13:06 (5,356 days old) by swestoyz (Cedar Falls, IA)
swestoyz's profile picture
Hey Gang -
After some long and hard thought, I've decided it is time for a few machines to move on to new homes.
Prices are very reasonable. If you are seriously interested please shoot me an email at benny59@mchsi.com. I am needing both machines to be picked up by September 20th. I've had many machines delivered via YouCrate - so that is an option too for pickup.
First up - early Whirlpool. This is the second version of the early Whirlpool with the red agitator (approx 1952). I've provided the link to when I first brought home the washer. Unfortunately I haven't used it since late 2006, but I suspect it wouldn't take much for it to wash again. I bought a new germicidal lamp for it a while back - Japanese style, but still does the job.
There is a little rust around the lid hinges, but other than it is in pretty good shape. The original water valve is long gone and was replaced with a hot/cold Maytag valve (therefore you have cold, warm, and hot temps, instead of the original thermostatically control hot, medium, warm).
CLICK HERE TO GO TO swestoyz's LINK
Post# 374903 , Reply# 1   8/26/2009 at 13:11 (5,356 days old) by swestoyz (Cedar Falls, IA)
Next up - L5 Westinghouse Laundromat (1950). This came from Chicago last fall. The matching 110v dryer is long gone. The machine will need a complete restoration. Speed changer and motor work fine. Pump is seized. Timer does not advance but does operate the machine. Weigh-to-Save scale is cracked but there is the possibility that it can be used again. The original boot is still soft and may be used by the future owner, if desired. While there is some rust it isn't bad enough that the body panels can't be sanded and painted.
A great candidate for a fun resto!
Again - both are very reasonable. Shoot me an email if you are interested. Thanks!
Post# 374904 , Reply# 2   8/26/2009 at 13:15 (5,356 days old) by swestoyz (Cedar Falls, IA)
Oh yeah, both machines are located in Waterloo, IA (50703)
Post# 374906 , Reply# 3   8/26/2009 at 13:21 (5,356 days old) by turquoisedude (.)
turquoisedude's profile picture
Gasp! You don't feel like tearing your L5 apart like I did with mine?? lol
If it helps a future buyer's decision, I was able to get the timer on mine fixed by Midwest Timer and I found a NIB water pump at Modern Parts in Ohio!
Post# 374911 , Reply# 4   8/26/2009 at 13:47 (5,356 days old) by volvoguy87 (Cincinnati, OH)
Moving the Westie.
volvoguy87's profile picture
I am afraid I cannot partake right now, but for future reference, how do you properly secure the tub/suspension on a Westie prior to moving it?
Dave
Post# 374922 , Reply# 5   8/26/2009 at 14:37 (5,356 days old) by turquoisedude (.)
Two places to secure
First is the bottom of the washer tub - if they are still around, there are two brackets to install between the bottom of the washer tub and the frame of the machine. In the photo there is a bar at a 45 degree angle to the tub - that is one of the lower mounting brackets. There should be one on each side.
Post# 374923 , Reply# 6   8/26/2009 at 14:40 (5,356 days old) by turquoisedude (.)
Top plates, too
There are bolts to attach the top counterbalance weights to the frame of the washer also. When I moved this CL8 washer on the weekend, I did not have the bolts. I used zip ties and they seemed to hold it reasonably well!
If you ever need it, I have a copy of a service manual that shows exactly where the brackets go (but doesn't say anything about bolt thread dimensions unfortunately).
Hope this helps!!
Post# 374945 , Reply# 7   8/26/2009 at 16:06 (5,356 days old) by christfr (st louis mo)
christfr's profile picture
oh drool another westy. she will make someone a wonderful pet
just a little love and your there. as long as the changer and motor are good your half way there. she can look like this
Post# 374947 , Reply# 8   8/26/2009 at 16:11 (5,356 days old) by alr2903 (TN)
Christfr, thats a sweet Laundromat. Ben i hope you find a good home for yours. alr2903
Post# 375010 , Reply# 9   8/26/2009 at 22:15 (5,356 days old) by tlee618 ()
Wow Chris, that Westy looks showroom new!! Amazing.
