Thread Number: 24458
Do Different Tags drain faster? |
Post# 379600 , Reply# 1   9/17/2009 at 05:21 (5,335 days old) by gyrafoam (Wytheville, VA)   |   | |
About 60 seconds is the accepted target for either. |
Post# 379605 , Reply# 2   9/17/2009 at 06:35 (5,335 days old) by magic clean ()   |   | |
your newer model machines have the built in siphon break? If so, it will slow draining somewhat compared to the older machines without. |
Post# 379621 , Reply# 4   9/17/2009 at 08:05 (5,334 days old) by yogitunes (New Jersey)   |   | |
what I do know is that there IS a conversion pulley for the motor that makes the pump go faster for say use in a basement when it has to pump higher and you may have this one installed, there's a parts store near me that has them, it appears to have the drive pulley and the pump pulley the same size, which makes the water pump out faster, about 35/40 seconds compared to 55 normally, no anti-siphon installed, an 8 foot hose now has to be strapped down in the tub because it now blast out like a rocket you may need a plumber, but first try pouring some lye/acid down the drain, and flush with hot water you have heated on the stove to boiling, run a garden hose down the drain to flush, or even run a snake down there before calling a plumber...you may just have detergent/softner/lint buildup just a thought! |
Post# 379719 , Reply# 5   9/17/2009 at 17:20 (5,334 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
