Thread Number: 24772
Maytag Performa Dryer-Who made this one? |
Post# 382959 , Reply# 1   10/5/2009 at 01:02 (5,317 days old) by travlincub321 ()   |   | |
Heres where the gasket is missing from the door |
Post# 382960 , Reply# 2   10/5/2009 at 01:03 (5,317 days old) by travlincub321 ()   |   | |
Heres the front.. Not sure if you can see the yellow part..Also there is some paint.enamal missing from the inside |
Post# 382961 , Reply# 3   10/5/2009 at 01:04 (5,317 days old) by travlincub321 ()   |   | |
Inside the drum... The dryer runs very smooth and doesnt make a noise or a peep |
Post# 382967 , Reply# 4   10/5/2009 at 02:22 (5,317 days old) by travlincub321 ()   |   | |
Now im trying to find a picture of a norge made maytag dryer.. my door handle is on the upper left corner.. Just ran a load through it on "low" (2 pairs of jeans anf 6 tshirts) it dried fine in 45 minutes |
Post# 383028 , Reply# 5   10/5/2009 at 11:52 (5,316 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 383126 , Reply# 7   10/5/2009 at 18:54 (5,316 days old) by toggleswitch2 ()   |   | |
The push-to-start button is the timer dial itself, which is SUCH A MAYTAG TURN-ON from yester-year! |
Post# 383164 , Reply# 9   10/5/2009 at 22:18 (5,316 days old) by toggleswitch2 ()   |   | |
Wanna know who made it and if I should sell it (electric dryers aren't popular here)or keep it until I find something better.. Does that mean gas is more popular or are dryers, in general, not all that popular? |
Post# 383181 , Reply# 11   10/5/2009 at 23:45 (5,316 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Was this thing located in an open laundry area for the residents to use? There's a lot of dust in the Vegas area, looks like that is your culprit. |
Post# 383182 , Reply# 12   10/6/2009 at 00:09 (5,316 days old) by travlincub321 ()   |   | |
No it wasn;t.. I do think it was either in a garage or a walkway... I wanna vaccume it out |
Post# 383325 , Reply# 13   10/6/2009 at 17:43 (5,315 days old) by kenmore81 ()   |   | |
Im also thinking the yellowing at the back is burnt dryer sheet residue. It happens with fabric softer to but only slightly. Dryer sheets are very waxy like. Bad for skin,dryers and the environment lol. |
Post# 383409 , Reply# 15   10/7/2009 at 02:51 (5,315 days old) by travlincub321 ()   |   | |
right now its just sitting unvented in my garage and it blew a crap load of lint out... i did wipe the inside out with alchol |
Post# 383476 , Reply# 16   10/7/2009 at 14:24 (5,314 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Up here in Reno, electric seems far more popular than gas. The house builders will run gas to the kitchen, furnace and water heater BUT not the few feet to the laundry room unless requested. Very FEW will have both 220v and gas available automatically. Plus, Reno also tends to have a large 'transitory' population and electric hookups are easier to find. Once you get out into the 'boonies', then you see more gas units in the form of propane units. That's a nice Herrin, IL. built dryer. Very popular unit and relatively easy to work on. I see quite a few with yellowish discoloration (if not outright cracked) on the left hand side of the console right near the top as that is right where the element is and too much heat messes with the plastic usually due to poor venting. Just use a putty knife to pop the top clips along the front and disconnect the front panel. It's amaizing just how much crap builds up under the filter right at the blower. The door gaskets are cheap and a piece of cake to install. As the Herrin dryers can be touchy about their airflow, the gasket should be done... RCD |
Post# 383513 , Reply# 17   10/7/2009 at 19:24 (5,314 days old) by travlincub321 ()   |   | |
Thanks... I orderd the gasket and it will be cleaned out tonight.. I am lucky in the fact i have both hookups i take it |
