Thread Number: 24777
Fisher & Paykel codes - Calling Dadoes?? |
Post# 383082 , Reply# 1   10/5/2009 at 15:07 (5,316 days old) by dadoes (TX, U.S. of A.)   |   | |
A new board must be programmed for the machine size (diameter of the basket, basically). NZ/Aus F&Ps are sold in three capacity sizes. U.S. models are all the largest size. If the size is not set properly, the following operational parameters will be wrong: auto water level sensing, high water level, water inlet flow rate, agitation profiles, shower rinse volume. With the power off, press and hold Wash Temp Up, then Power at the same time. Should get 4 short beeps. Set the size accordingly, then press Power to exit. • 5kg & 5.5kg = Wash Temp Up / Cold light • 6.5kg = Water Level Up / Low level light • 7.5kg = Spin Speed Up / Hold spin light Spin light lit as a fault code is Code 1: Motor Controller Fault - The Motor Controller has encountered an error when writing to an EEPROM address. Action: Replace the motor controller. Which you say has already been done ... so hopefully she's misreporting the spin light. :-) I've sent a service manual for Phase 1 thru 5 230v machines to the e-mail addy on your profile. 709 is Phase 5. Far as I'm aware, the U.S. market went from GWL08 to GWL10, there was no GWL09. |
