Thread Number: 24918
Solid tubs |
Post# 384822 , Reply# 1   10/12/2009 at 21:11 (5,314 days old) by gyrafoam (Wytheville, VA)   |   | |
I'm thinking SQ was the last one building solid-tub machines. |
Post# 384824 , Reply# 2   10/12/2009 at 21:22 (5,314 days old) by lebron (Minnesota)   |   | |
Post# 384836 , Reply# 3   10/12/2009 at 22:13 (5,314 days old) by circlew (NE Cincinnati OH area)   |   | |
Don't know for sure, but wouldn't be surprised if WCI was the first to use plastic outer tubs, as they cheapened whatever they got ahold of. So maybe Kelvinator & Gibson. |
Post# 384838 , Reply# 4   10/12/2009 at 22:17 (5,314 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 384848 , Reply# 5   10/12/2009 at 23:36 (5,314 days old) by rinso (Meridian Idaho)   |   | |
Consumer Reports always rated solid tub machines poor in sand disposal. IIRC, the Whirlpool/KM direct drives machines were the first with plastic outer tubs. GE and WCI Frigidaire seemed to be the first with plastic inner tubs. Just my impressions, I could be wrong. |
Post# 384849 , Reply# 6   10/12/2009 at 23:53 (5,314 days old) by peteski50 (New York)   |   | |
Post# 384875 , Reply# 7   10/13/2009 at 07:53 (5,314 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 384882 , Reply# 8   10/13/2009 at 08:52 (5,314 days old) by cleanteamofny ((Monroe, New York)   |   | |
Post# 384949 , Reply# 9   10/13/2009 at 13:36 (5,314 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
The plastic outer tub pre-dates the Whirlpool direct-drive machines by years - WCI was using it on their compact washers in the mid 70's and then that same mechanism design was incorporated into the Skinny-Mini cabinet and available on the market by 8/79 once the takeover of Frigidaire by WCI was completed earlier that year.
Post# 385039 , Reply# 10   10/13/2009 at 17:48 (5,313 days old) by mrb627 (Buford, GA)   |   | |
Post# 385118 , Reply# 11   10/13/2009 at 22:10 (5,313 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 385119 , Reply# 12   10/13/2009 at 22:13 (5,313 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 385184 , Reply# 13   10/14/2009 at 06:38 (5,313 days old) by mrb627 (Buford, GA)   |   | |
Post# 385197 , Reply# 14   10/14/2009 at 08:23 (5,313 days old) by lesto (Atlanta)   |   | |
Steve K and I put a new motor on one similar to this earlier this year here in Atlanta. It's also a non-solenoid machine but does have the stainless steel solid tub and overflow rinses. |
Post# 385482 , Reply# 16   10/15/2009 at 07:17 (5,312 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 385522 , Reply# 17   10/15/2009 at 12:16 (5,312 days old) by nmassman44 (Brooksville Florida)   |   | |
The new Speed Queens have am excellent warranty...and it is...drum roll please.... 3 years parts and labor 5 years limited warranty on cabinet assembly against rust inside and out. Year 4 thru 5 parts only limited warranty. 5 year year limited warranty on the motor. 10 years limited warranty on transmission assembly. Lifetime warranty stainless steel washbasket and outer tub. Not bad I say and better than a 1 year only warranty most others have. |
Post# 386663 , Reply# 18   10/20/2009 at 20:00 (5,306 days old) by ingliscanada ()   |   | |
SQ went to perforated tubs sometime in the early 80s. They were the last washers that came with a solid tub. |
Post# 386689 , Reply# 19   10/20/2009 at 20:44 (5,306 days old) by mrcleanjeans (milwaukee wi)   |   | |
In 1980 Speed Queen went to a perforated tub. |
