Thread Number: 25136
Bellows part # questions |
Post# 387741   10/24/2009 at 11:42 (5,297 days old) by lebron (Minnesota)   |   | |
Post# 387886 , Reply# 1   10/24/2009 at 21:58 (5,297 days old) by rollermatic (cincinnati)   |   | |
is the frigidaire part no. i have for the oil bellows. it will fit both the 1-8 and rollermatic models. the water bellows are different, i have bought both this summer from the web and thru mark michaels. on the web i bought from dave's repair. i also bought from larry at modern parts in parma, but i think i got all he had left. the 1-18 water bellows no. is 638860 and for the rollermatic it's 5433576. they are different in design. i take it you found a source for bellows?!! hope so! i have not attempted to loosen the top nut on my agitator any more yet, am letting it soak in pb blaster. may try heat, wrapping a peice of aluminum around inside of agitator to keep plastic from being damaged by torch. gonna leave it for a week or so then come back to it. if you come up with any ideas to fix your same problem please let me know. |
Post# 387887 , Reply# 2   10/24/2009 at 22:11 (5,297 days old) by lebron (Minnesota)   |   | |
Post# 388154 , Reply# 4   10/26/2009 at 08:43 (5,295 days old) by rollermatic (cincinnati)   |   | |
maybe a balloon or God forbid, even a condom! wouldn't that be fun! i do know that for a limited time the 1-18's did not have an oil bellows. and if the water bellows is doing it's job no water will be inside of it anyway. if it leaks there will be moisture at least, if it leaks enough then there is a real possibility of water getting into the shaft. there are places on the web that sell bellows, perhaps a similiar bellows could be found that would fit. |
Post# 388334 , Reply# 6   10/26/2009 at 18:20 (5,295 days old) by steve1-18 (Grovetown (Augusta), GA)   |   | |
I wonder if they could make door boots for some of our older front-loaders? Mmmmmmmmmm... |
Post# 388388 , Reply# 7   10/27/2009 at 00:09 (5,294 days old) by rollermatic (cincinnati)   |   | |
