Thread Number: 25298
Maytag "12" Series Washer |
Post# 390030   11/1/2009 at 15:56 (5,289 days old) by scrubflex (bronx, new york)   |   | |
Does anyone know how long is the SPRAY RINSE time and the RINSE cycle time for the Maytag A712, A612 os A512 washer are? |
Post# 390035 , Reply# 1   11/1/2009 at 16:16 (5,289 days old) by bajaespuma (Connecticut)   |   | |
Post# 390047 , Reply# 2   11/1/2009 at 16:59 (5,289 days old) by scrubflex (bronx, new york)   |   | |
How about the rinse agitating time? |
Post# 390053 , Reply# 3   11/1/2009 at 17:15 (5,289 days old) by qsd-dan (West)   |   | |
Post# 390077 , Reply# 5   11/1/2009 at 20:06 (5,289 days old) by peterh770 (Marietta, GA)   |   | |
Post# 390078 , Reply# 6   11/1/2009 at 20:09 (5,289 days old) by qsd-dan (West)   |   | |
"Ok! Does anyone know if there is any agitating time towards the end of the AUTOMATIC PRESOAK cycle of the A712, etc?" I haven't stood around to watch the automatic pre-soak cycle in the 712 for some time now, but I do remember it going from soaking in the per-soak cycle to agitating in the regular cycle. If the dial isn't set perfectly on the 12 min mark of the regular cycle to wash, there's a delay (still in the soaking portion of the pre-soak cycle) until the timer reaches that point. I have the schematics at home (currently at work) which lay out the timer increments and can scan and post them if you wish. "This is off the subject but, I'm beginning to suspect the power-fin agitator is unable to do a good job with small washloads using the lowest water level." In 23 years, I have never ran any of my Maytags lower than a med size load (wasteful, IMHO), but I imagine if one were to set the water level extremely low, the clothes would only slosh back and forth with the agitator. The fins need to be under water to create rollover. |
Post# 390079 , Reply# 7   11/1/2009 at 20:09 (5,289 days old) by appnut (TX)   |   | |
that would have to be an extremely small wash load. No towels, just shirts, or undies, or stuff like that. The last Maytag I saw/used with the small water level was an A606 and an A408. The later level was so low, there was barely enough water that got to the mesh leve3l of the filter, so filtering is very minimal compared to medium. A lot of small loads are too large for small and end up having to be put on medium, why I wished they'd put variable water levels in long before they did.
Post# 390089 , Reply# 9   11/1/2009 at 21:28 (5,289 days old) by qsd-dan (West)   |   | |
"Here it is guys, is there anyway I can convince one of you to make a youtube video of a deep tub small level size (wash/rinse/spin) wash load for me." I can make a vid, but with my 712 having an infinite water level slider, you'll have to give me a near exact figure, in inches, how high of a water level you're after. Well, I guess I could drag one of the 806's to laundry room and swap out.... |
Post# 390092 , Reply# 10   11/1/2009 at 21:48 (5,289 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 390093 , Reply# 11   11/1/2009 at 21:53 (5,289 days old) by gadgetgary (Bristol,CT)   |   | |
According to the manual Small Use when tub is less than 1/3 full. Tub fills with 9 gal. The level of water is below where the lint filter can function. Medium Use when tub is from 1/3 to 1/2 full. Tub fills with 12-1/2 gal. Large Use when tub is from 1/2 to 3/4. Tub fills with 16 gal. Extra Large Use when tub is 3/4 to full. Tub fills with 19 gal. |
Post# 390094 , Reply# 12   11/1/2009 at 21:57 (5,289 days old) by appnut (TX)   |   | |
Post# 390095 , Reply# 13   11/1/2009 at 22:00 (5,289 days old) by appnut (TX)   |   | |
Post# 390111 , Reply# 14   11/1/2009 at 22:48 (5,289 days old) by lebron (Minnesota)   |   | |
Post# 390125 , Reply# 15   11/2/2009 at 00:10 (5,289 days old) by alr2903 (TN)   |   | |
Lebron, is right, that is what makes a solid tub so cool, any water level wash. Full tub of water for rinse. I never have less than 1/2 a load and always press large during the first spin. |
Post# 390203 , Reply# 17   11/2/2009 at 09:28 (5,288 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 390238 , Reply# 18   11/2/2009 at 11:48 (5,288 days old) by scrubflex (bronx, new york)   |   | |
Where did you find them? |
Post# 390255 , Reply# 19   11/2/2009 at 12:52 (5,288 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I do one "small" load a week in my A606 (deep tub), the kitchen rags. hot / gentle / small / 10 minutes Ken D. |
Post# 390261 , Reply# 20   11/2/2009 at 13:06 (5,288 days old) by scrubflex (bronx, new york)   |   | |
I've always enjoyed watching the splashing, sloshing and swishing of small washloads. |
Post# 390266 , Reply# 21   11/2/2009 at 14:10 (5,288 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 390322 , Reply# 22   11/2/2009 at 20:11 (5,288 days old) by scrubflex (bronx, new york)   |   | |
Qsd-dan, please let me know when you make the video. |
Post# 390330 , Reply# 23   11/2/2009 at 21:00 (5,288 days old) by qsd-dan (West)   |   | |
Post# 390347 , Reply# 25   11/2/2009 at 22:21 (5,288 days old) by qsd-dan (West)   |   | |
Post# 390350 , Reply# 26   11/2/2009 at 22:36 (5,288 days old) by scrubflex (bronx, new york)   |   | |
let me know if you hear about any A712's. |
Post# 390358 , Reply# 27   11/2/2009 at 23:08 (5,288 days old) by scrubflex (bronx, new york)   |   | |
Qsd-dan, can you interchange Maytag washer control panels? Say I have an A712 and wanted to install an A9900AAW "Digital Computer Touch Controls" control panel on the A712, could that work? |
Post# 390363 , Reply# 28   11/2/2009 at 23:52 (5,288 days old) by qsd-dan (West)   |   | |
"Qsd-dan, can you interchange Maytag washer control panels? Say I have an A712 and wanted to install an A9900AAW "Digital Computer Touch Controls" control panel on the A712, could that work?" Not sure about swapping panels between different generations. I know any 10-12 series panels can be swapped around. I personally swapped in a 712 panel on an 490. Any 06-09 control panel can be swapped. Unfortunately, I don't know anything about the LAT series. I'm a hardcore helical transmission fan and plan to stay that way. I faintly remember someone here claiming to have swapped an LAT9806, or something very similar, on a 712. I would be interested in doing that for greater flexibility, but I'm pretty sure RCD wouldn't let me rip into one of those solely for the control panel if one happened to end up in his haul away pile, lol. |
Post# 390373 , Reply# 30   11/3/2009 at 00:26 (5,288 days old) by scrubflex (bronx, new york)   |   | |
A9900 |
Post# 390375 , Reply# 31   11/3/2009 at 00:34 (5,288 days old) by qsd-dan (West)   |   | |
Post# 390376 , Reply# 32   11/3/2009 at 00:41 (5,288 days old) by qsd-dan (West)   |   | |
Post# 390377 , Reply# 33   11/3/2009 at 00:45 (5,288 days old) by scrubflex (bronx, new york)   |   | |
LOL!!! a whole new lustful desire is right...I know, I KNOW!!. |
Post# 390378 , Reply# 34   11/3/2009 at 00:58 (5,288 days old) by scrubflex (bronx, new york)   |   | |
The model number is LAT9904AAW. I didn't realize the dark control panel only has 3 speed combinations. A 4 speed selector is much better. I use that speed combo often. |
Post# 390406 , Reply# 35   11/3/2009 at 06:43 (5,287 days old) by appnut (TX)   |   | |
Post# 390447 , Reply# 36   11/3/2009 at 10:53 (5,287 days old) by scrubflex (bronx, new york)   |   | |
the Gentle-Fast setting that is and "9900 control panel SAME"...I mean the same. |
Post# 390504 , Reply# 37   11/3/2009 at 15:14 (5,287 days old) by qsd-dan (West)   |   | |
Post# 390994 , Reply# 38   11/5/2009 at 15:03 (5,285 days old) by qsd-dan (West)   |   | |
Surprisingly, the smaller load performed better than I would have thought. I included the entire first spin cycle so you get an idea how the spray rinse acts. The rinse cycle gives a clearer picture of rollover due to the lack of suds, however, the extra items I included during the wash cycle clearly teeters the load on the verge of being overloaded.
CLICK HERE TO GO TO qsd-dan's LINK |
Post# 391037 , Reply# 39   11/5/2009 at 19:02 (5,285 days old) by mrb627 (Buford, GA)   |   | |
Post# 391063 , Reply# 41   11/5/2009 at 21:00 (5,285 days old) by 70series ( Connecticut.)   |   | |
Thanks for the vid. Haven't seen a Helical Drive Maytag operate on Small in 10 years, and that brings back memories. Have a good one, James |
Post# 391080 , Reply# 42   11/5/2009 at 21:59 (5,285 days old) by scrubflex (bronx, new york)   |   | |
Qsd-dan, do you think this LAT9806AAW control panel can be a direct swap with the A712? |
Post# 391082 , Reply# 43   11/5/2009 at 22:05 (5,285 days old) by scrubflex (bronx, new york)   |   | |
left angle |
Post# 391083 , Reply# 44   11/5/2009 at 22:05 (5,285 days old) by qsd-dan (West)   |   | |
Post# 391084 , Reply# 45   11/5/2009 at 22:06 (5,285 days old) by scrubflex (bronx, new york)   |   | |
left side close-up |
Post# 391085 , Reply# 46   11/5/2009 at 22:07 (5,285 days old) by scrubflex (bronx, new york)   |   | |
control dial |
Post# 391090 , Reply# 47   11/5/2009 at 22:39 (5,285 days old) by qsd-dan (West)   |   | |
Well, I have raised the overall water level buy a 1/2" or so (water level even with the bottom of the lint filter), in order to wash large blankets and the couch covers on a 3 week basis. "Does your A806 use as much water for small or less?" Haven't tried it yet, but I'd imagine the water level will be higher as the levels are on the higher end of each load size (if that makes sense). Last night I finally got 806 washer #4 unloaded from the truck and my OCD kicked into high gear, so I ended up digging out the digital calipers out and spent a few hours making very tedious adjustments. I'll see if I have time to get it hooked up tomorrow for some test runs. |
Post# 391098 , Reply# 48   11/5/2009 at 23:02 (5,285 days old) by qsd-dan (West)   |   | |
Here's a 712 for $80 for the west coast guys.
CLICK HERE TO GO TO qsd-dan's LINK on Orange County, CA Craigslist |
Post# 391099 , Reply# 49   11/5/2009 at 23:05 (5,285 days old) by qsd-dan (West)   |   | |
A little hard to tell by the pic, but this looks like a 712 set.
CLICK HERE TO GO TO qsd-dan's LINK on Sacramento Craigslist |
