Thread Number: 25588
Norge Burpalator Agitator Question |
Post# 393729 , Reply# 1   11/16/2009 at 14:41 (5,274 days old) by mrb627 (Buford, GA)   |   | |
Post# 393931 , Reply# 2   11/17/2009 at 06:44 (5,274 days old) by bobbyderegis (Boston)   |   | |
What's foaming pipe snake? Bobby in Boston |
Post# 393935 , Reply# 3   11/17/2009 at 06:56 (5,274 days old) by mrb627 (Buford, GA)   |   | |
Post# 394003 , Reply# 7   11/17/2009 at 12:43 (5,273 days old) by mickeyd (Hamburg NY)   |   | |
There's a lot of physics and hydrodynamics going on there: large holes, strong upward thrust of water, powerful oscillations--and, Hey!-- it's a Norge, Baby! Have had a lot of luck with a gallon of white vinegar and a gallon of water heated for other problems, but it's worth a try. If you have the extra-low water level available, heat up some vinegar and water, and let her agitate and/or if you can't or don't have enough solution to achieve agitation, let the drain hose squirt the solution into the holes. With relative ease, you can hold the rim of the tub to keep it from spinning. On second thought, the drain method probably won't be so effective, but the agitation with scalding vinegar and water is worth a try. I was able to loosen a stuck spindrier in an Easy after dozens of failures; nothing else worked except the hot vinegar, etc. Hope it helps. |
Post# 394015 , Reply# 8   11/17/2009 at 13:49 (5,273 days old) by mrb627 (Buford, GA)   |   | |
Post# 394016 , Reply# 9   11/17/2009 at 13:50 (5,273 days old) by mrb627 (Buford, GA)   |   | |
Post# 394025 , Reply# 10   11/17/2009 at 14:55 (5,273 days old) by bobbyderegis (Boston)   |   | |
HAHAHA! I bet a pipe cleaner would do the trick, but I can't come up with one that is that flexible. The gunk is pretty stuck in there, I don't know if air would blow it out. Bobby in Boston |
Post# 394029 , Reply# 11   11/17/2009 at 15:21 (5,273 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 394051 , Reply# 13   11/17/2009 at 17:00 (5,273 days old) by bobbyderegis (Boston)   |   | |
One can see the krud when held up to the light: |
Post# 394052 , Reply# 14   11/17/2009 at 17:04 (5,273 days old) by bobbyderegis (Boston)   |   | |
Cracked agitator to be replaced and frozen on the shaft: |
Post# 394053 , Reply# 15   11/17/2009 at 17:05 (5,273 days old) by bobbyderegis (Boston)   |   | |
The Norgebeast herself, awaiting restoration: |
