Thread Number: 25967
Swapping Maytag Consoles |
Post# 398848   12/10/2009 at 21:14 (5,250 days old) by scrubflex (bronx, new york)   |   | |
Drew here's the A712 |
Post# 398851 , Reply# 1   12/10/2009 at 21:18 (5,250 days old) by scrubflex (bronx, new york)   |   | |
Closer angle |
Post# 398852 , Reply# 2   12/10/2009 at 21:22 (5,250 days old) by scrubflex (bronx, new york)   |   | |
The LAT9806AAW |
Post# 398854 , Reply# 3   12/10/2009 at 21:27 (5,250 days old) by scrubflex (bronx, new york)   |   | |
Other angle...what do you think Drew? |
Post# 398876 , Reply# 4   12/10/2009 at 23:36 (5,250 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Switching them would be difficult. the tops would not be compatible with different holes located in different places. The openings also would not line up with each other. The tub covers are different size openings... Why do you want to change consoles? Is it features or is it wanting the newer style features with the helical transmission? RCD |
Post# 399101 , Reply# 6   12/11/2009 at 18:44 (5,249 days old) by scrubflex (bronx, new york)   |   | |
I'd just change console only and leave everything else the same. |
Post# 399106 , Reply# 7   12/11/2009 at 19:22 (5,249 days old) by yogitunes (New Jersey)   |   | |
Harry A little work, but you can switch the tranny from a orbital to a helical...everything is supposed to match up the same...you will need the brake tool and the tool for the tub bolt, maybe new seals while your at it....cause the only thing thats different is the actual BODY of the tranny....I'm curious to change this on my DC set, wanting the slower longer stroke of the helical.... but wouldn't an Atlantis version of the Maytag with the norge tranny give you the trans stroke and the control panel features you want?.....I'm looking for this myself first before I consider the change out..... |
Post# 399120 , Reply# 8   12/11/2009 at 22:41 (5,249 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 399168 , Reply# 10   12/12/2009 at 02:03 (5,248 days old) by mayfan69 (Brisbane Queensland Australia)   |   | |
Harry, There is NO way a helical drive long stroke transmission can be used in the Atlantis...COMPLETELY different designs. I really think it's about time YOU showed US what you're planning to do to create this SUPER Hybrid Maytag washer you've been talking about and put your ideas into practice. Cheers Leon |
Post# 399184 , Reply# 12   12/12/2009 at 05:38 (5,248 days old) by goatfarmer (South Bend, home of Champions)   |   | |
