Thread Number: 26043
Reversing my position. |
Post# 399901   12/15/2009 at 17:32 (5,245 days old) by mixfinder ()   |   | |
The new Maytag set I'm using have doors that open against each other. Is there any special advice I should have before trying to reverse the door swing on the washer? |
Post# 399930 , Reply# 1   12/15/2009 at 20:22 (5,245 days old) by yogitunes (New Jersey)   |   | |
easy as pie to flip the door hinges around, you should have then both done in under 10 minutes....instructions are in the books.....or go to www.searspartsdirect.com....type... in your model number and print out your manuals
Post# 399968 , Reply# 3   12/15/2009 at 23:57 (5,244 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The door switch is a piece of cake. You can also go online to Maytag.com and download the use&care and installation books in PDF format. I'd also think about registering them to you (also done online)in case of any future issues. Man, I'm liking those, you lucky guy... BTW, there is also a 'help' database included in each machine's programming. Find the menu and it'll walk you thru anything. The 'Stain brain' feature is also way cool. Look up a stain and it'll tell you the best way to clean it with the washer AND if you want you can push one icon on the screen and the washer will preset itself for that stain. Too cool! RCD |
Post# 403593 , Reply# 4   1/3/2010 at 13:18 (5,226 days old) by johnb300m (Chicago)   |   | |
