Thread Number: 26433
Easy washer POD |
Post# 405735   1/13/2010 at 04:09 (5,216 days old) by wilkinsservis (Melbourne Australia)   |   | |
Post# 405737 , Reply# 1   1/13/2010 at 04:32 (5,216 days old) by tolivac (greenville nc)   |   | |
Now THAT Easy washer could be a "DD" washer that won't shred your clothes!Would be interesting to somehow find one and try it. |
Post# 405748 , Reply# 2   1/13/2010 at 06:45 (5,216 days old) by mrb627 (Buford, GA)   |   | |
Post# 405750 , Reply# 3   1/13/2010 at 06:52 (5,216 days old) by polkanut (Wausau, WI )   |   | |
Post# 405772 , Reply# 6   1/13/2010 at 08:49 (5,216 days old) by ingliscanada ()   |   | |
So in the 70's, when WCI took over, Hupp must've went "Hupp-2-3-4" out of the picture :p |
Post# 405777 , Reply# 7   1/13/2010 at 09:28 (5,216 days old) by unimatic1140 (Minneapolis)   |   | |
This model is a 1965 model and its direct drive transmission which was not the first. The first direct drives automatic washer mechanisms were both the 1947 Frigidaire Unimatic and the 1947 General Electric AW6. The fact that is has a stainless steel wash tub makes it even more extremely rare, what a find it would be. I have a 1963 Easy... Ding - Score... and YAY for Easy Washdays! and Easy Mechanicals and The Easy Washes Live |
Post# 405781 , Reply# 8   1/13/2010 at 09:58 (5,216 days old) by programcomputer (Ann Arbor Michigan, USA)   |   | |
I just had a chance to check out the address for the Easy POD washers built by Hupp on google maps which is located in the Ivanhoe Rd. Corridor. It is apparent the either Easy had by this point left Syracuse New York, for this newer factory, or was using it for the production of automatic washers and dryers. This factory, to all of my searchings, and you can really tell by aerial shots; was once "most likely" part of the large Apex Electrical Manufacturing Company compound. This plant must have been purchased from the sale off of Apex Electrical sometime in the late 1950's, as we've all learned that Apex was around until 1955-56 or so. You can tell from this photo, as well as the one from the air, that a large portion of this factory was demolished, as you can see that the building used to run RIGHT up to the sidewalk. If we use the year 1965 as the date for this Easy brochure, 45 years "does" change the landscape quite a bit.....
CLICK HERE TO GO TO programcomputer's LINK |
Post# 405782 , Reply# 9   1/13/2010 at 10:00 (5,216 days old) by programcomputer (Ann Arbor Michigan, USA)   |   | |
Post# 405794 , Reply# 10   1/13/2010 at 11:08 (5,216 days old) by mickeyd (Hamburg NY)   |   | |
Just look at that gorgeous agitator with a great big heart around it almost as if an AWorg lover like Robert photo-shopped it. Can't wait to enjoy the links after the tea is brewed--will be going crazy with pleasure shortly. Thank You! (Gregm of Worcester, Massachusetts sold a mint one 2 years ago to perhaps a non-member because we didn't get a thread unless I missed it.) |
Post# 405801 , Reply# 11   1/13/2010 at 11:44 (5,216 days old) by programcomputer (Ann Arbor Michigan, USA)   |   | |
I am going off from data supplied from a back issue of the VCCC newsletter from spring of 2000, it gives in the letter a complete list of all vacuum cleaner manufacturer's and their addresses circa. 1940. The hardest one to find was Electric Vacuum Cleaner Company of Cleveland Ohio (or Premier and later General Electric the back to Premier.), and that was because the was NO mailing address. The easiest one was the 1070 E.152nd Street location of Apex. Okay my surprise was founded a few months ago when I went on a search for the address of Premier Electric, who made several vacuums I have which gave a mfg. address of 1732 Ivanhoe Rd which brought to my very eyes the last factory of Premier Electric. Another suprise was the finding if you go down to 16234 Euclid Avenue, on the south side of that building you see VERY plainly General Electric. If you look from a large shot aerial view, Apex and Electric Vacuum Cleaner Company werre neighbors seperated by railroad track, adn now we come to find out that it was ALSO later part of Hupp Corporation. Heres how I believe the situation and topography went. The Apex Company Started at the tri-corner of 152nd st East Side and West side of the street, and St Clair Avenue and Ivanhoe Rd. went straight down on both sides of 152nd, ( with possibly some)different company factories along the way on the west side until you hit Woodworth Rd. Even where you see the new track/sports field and up to the shopping plaza on the N.E. corner of St Clair Avenue and 152nd, was all factory site. You can see it on the ground and the fact that many of those things are new developments. Now, Woodworth Rd, to the extreme south of the Apex complex going east is all still fine until you hit the railroad tracks, then following the tracks over to the West side of Ivanhoe Rd. At first I figured that Apex then continued all the way back up to St.Clair completing the kinda trainglish property line, and looking from ground level all the factories looked like they were built the same way with the same building signitures. Apex was huge at one point, and the factory grounds prove this. But No Apex was large enough that they also Continued their property line, AND factories, as the later Hupp plant has the same build signitures as the buildings the toher side of Ivanhoe. So, from the E. Side of Ivanhoe and the Railroad tracks and followed the tracks NE until the property line ended at London St. Then the property line went N.W until you hit Mandalay Avenue. Mandalay Av.follows a kinda S. Westerly slope until it ends again back at Ivanhoe Avenue. I do have a APEX document that shows the company from the air as well, and besides a few liberties given to make it look pretty seems fairly on spot with what you see, and I've tried to explain. The funny part is, is that SOUTH of the RR tracks and W. Of Ivanhoe N. of Euclid Rd, and E. Of Noble Rd. were all once the factories of Premier Electric/Electric Vacuum Cleaner Co, and subsequently at some point General Electric. Confusing enough for ya? So the aerial shot of what became Hupp Corporation,and subsequently the Easy washing machine plant was the building that encompassed the East side of Ivanhoe Rd and was "most likely" part of what was Apex. ITs not super hard to find our where it all happened..... Kinda a neat look see!!! Chad Ann Arbor Michigan CLICK HERE TO GO TO programcomputer's LINK |
Post# 405824 , Reply# 12   1/13/2010 at 14:26 (5,216 days old) by appliguy (Oakton Va.)   |   | |
Post# 405840 , Reply# 13   1/13/2010 at 16:46 (5,216 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 405885 , Reply# 15   1/13/2010 at 19:45 (5,216 days old) by yogitunes (New Jersey)   |   | |
Post# 405890 , Reply# 16   1/13/2010 at 20:46 (5,216 days old) by ingliscanada ()   |   | |
The Easy washer had a direct-drive tranny, which Speed Queen never had. |
Post# 405891 , Reply# 17   1/13/2010 at 21:08 (5,215 days old) by danmantn (Tennessee)   |   | |
Post# 406033 , Reply# 18   1/14/2010 at 10:31 (5,215 days old) by autowasherfreak ()   |   | |
I missed this picture, would someone be so kind as to email it to me. jkalin196511@gmail.com thanks! |
Post# 406362 , Reply# 19   1/16/2010 at 01:50 (5,213 days old) by nanook (Seattle)   |   | |
Post# 410040 , Reply# 20   1/27/2010 at 17:38 (5,202 days old) by geoff (Cape Coral, FL)   |   | |
I actually have John's EASY given to me by GregM. here is a video of it in action. It is a 1962 model.
CLICK HERE TO GO TO geoff's LINK |
