Thread Number: 27259
Maytag Neptune Top Loader |
Post# 418906 , Reply# 1   2/27/2010 at 01:20 (5,172 days old) by spankomatic (Ukiah,CA)   |   | |
Post# 418907 , Reply# 2   2/27/2010 at 01:27 (5,172 days old) by bbqchickenwings ()   |   | |
No pics No warranty i know of No Recalls Its about 5 years old from sears.. If i can't figure it out soon, im tossing it for a Front Loader |
Post# 419387 , Reply# 3   2/28/2010 at 20:37 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
From where exactly does water splash out? Around the lid? From under the machine? The nature of the wash action should preclude that from happening ... unless perhaps something has gone wrong with the clutch and it's spinning at a high speed when it should only be tumbling. Suggestion: Since the lid locks and you can't otherwise watch it run, unlatch and raise the top so you see (with the lid remaining closed) if there's something obviously wrong. Slip a putty knife into the seam about 2" in from each side, press gently to release the latch clips while lifting on the top. Service info can be fetched at www.servicematters.com.... |
Post# 419391 , Reply# 4   2/28/2010 at 20:52 (5,170 days old) by bbqchickenwings ()   |   | |
Yes its coming from under the top and down the cabinet.. And it makes a horrible clicking noise.. Water goes every where |
Post# 419424 , Reply# 5   2/28/2010 at 22:11 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419426 , Reply# 6   2/28/2010 at 22:12 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419427 , Reply# 7   2/28/2010 at 22:13 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419428 , Reply# 8   2/28/2010 at 22:14 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419430 , Reply# 9   2/28/2010 at 22:16 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419431 , Reply# 10   2/28/2010 at 22:16 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419432 , Reply# 11   2/28/2010 at 22:17 (5,170 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 419712 , Reply# 13   3/1/2010 at 20:36 (5,169 days old) by DADoES (TX, U.S. of A.)   |   | |
I'd guess the clutch is at fault. It mounts directly to the center drive shaft under the tub. Looks like a large pulley, the belt fits around it from the motor. Part # 12002211. A tad expensive. RepairClinic.com lists it $148. PartsTap.com $147. SearsPartsDirect.com $161. Check your other sources as well. |
