Thread Number: 27297
Packing Example |
Post# 419311   2/28/2010 at 15:31 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Ok, here it is. Start w/ a Singer #12 fiddle-based sewing machine. |
Post# 419312 , Reply# 1   2/28/2010 at 15:32 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Secure the little lever that holds the s/m on the wood base. Don't trust that it will stay there on its own (I loves me zip-ties!). |
Post# 419313 , Reply# 2   2/28/2010 at 15:33 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Disengage the cranking mechanism from the flywheel (red arrow), and secure both (more zip ties!!). |
Post# 419314 , Reply# 3   2/28/2010 at 15:35 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Don't trust that the little lever you zip-tied will hold the machine securely to the base. Band the base of the s/m to the wood base with strong tape, but tape over newspaper so as not to damage finishes. |
Post# 419315 , Reply# 4   2/28/2010 at 15:35 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Secure the bobbin winder so it doesn't flop around. |
Post# 419317 , Reply# 6   2/28/2010 at 15:38 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Securely tape the bottom of your box. I use fiberglass-reinforced paper tape, and the H or I method which uses 3 pieces of tape. |
Post# 419318 , Reply# 7   2/28/2010 at 15:39 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Give a good base (this will actually be the end of the box) with a good 6" of balled newspaper and/or paper grocery bags. |
Post# 419321 , Reply# 9   2/28/2010 at 15:44 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
Finish filling the box, tape securely, and add FRAGILE labels that also have This End UP and arrows on them. I figured it out and the labels only cost about $0.05 each. 20 cents per box for that little extra security is cheap. |
Post# 419323 , Reply# 10   2/28/2010 at 15:46 (5,171 days old) by perc-o-prince (Southboro, Mass)   |   | |
That's it! Every machine like this gets packed this way every time. It takes about 1/2 an hour since I'm used to it now, but the pay-off is worth it in repeat business, word-of-mouth in the community collecting such things, and feedback on eBay. Chuck |
Post# 419415 , Reply# 13   2/28/2010 at 21:38 (5,171 days old) by circlew (NE Cincinnati OH area)   |   | |
Very well done! Should get there in top-notch condition. |
Post# 419497 , Reply# 14   3/1/2010 at 09:10 (5,171 days old) by elginkid (Cincinnati, OH)   |   | |
