Thread Number: 28215
DD Kenmore motor noise |
Post# 431627 , Reply# 2   4/27/2010 at 20:51 (5,112 days old) by davek ()   |   | |
I'll tear it down and check the pump. I've done two loads with the noise to see if it changed and it hasn't. That's several directional cycles... |
Post# 431689 , Reply# 3   4/28/2010 at 08:00 (5,111 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 436731 , Reply# 5   5/21/2010 at 22:46 (5,088 days old) by cfz2882 (Belle Fourche,SD)   |   | |
as long as both clips are in place and all four locating pegs are there really can't mess up though if motor shaft is badly rusted impeller may wobble and cause seal leakage-also best to use genuine FSP parts. |
Post# 436761 , Reply# 6   5/22/2010 at 04:39 (5,088 days old) by davek ()   |   | |
It was a genuine FSP, and everything installed smoothly and properly when I put it in. There's no play in the motor shaft. |
Post# 436926 , Reply# 7   5/23/2010 at 10:25 (5,086 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I have never seen a noisey pump on a DD washer that did not have a foreign object caught in it. Either keep using the machine the object will often work it self out or if you do replace it crack the old one open along where its heat welded together and see what you are getting caught in it. If you are careful and a little lucky breaking the old pump open you may be able to epoxy it back together and reuse it I did this with several Calypso pumps and they worked fine.
Post# 437038 , Reply# 8   5/23/2010 at 21:18 (5,086 days old) by davek ()   |   | |
It needs a new pump, not because of noise, but because it's leaking at the shaft seal. The last load I did made a 1' puddle. I won't do another until I change the pump. |
