Thread Number: 28440
MAH4000AWQ motor |
Post# 434870 , Reply# 1   5/12/2010 at 11:32 (5,098 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The motor may be out BUT the motor control board may be screwed up too. I've put the conversion kit on my MAH4000AWW washer and haven't looked back. The new motor is a million times quieter and the control board is built with better heat sinks for the triacs and a line filter as well. I really don't see many of the new style motor/controls crap out. I highly recommend changing the belt at the same time. If you have the older 'Dayco' mfg belt, change it for the newer Hutchinson mfg. The conversion is really easy to do, too. Good luck!
RCD |
