Thread Number: 29283
Lady Kenmore Help |
Post# 445541   6/29/2010 at 13:03 (5,050 days old) by lebron (Minnesota)   |   | |
So awhile back, trying to get the agitator out of my '71 Lady K, I broke the agitator nut. It is now broken off inside the agitator shaft. I beleive my best bet would be to replace the agitator shaft? Gordon, et al., what are your thoughts on this? Now how do I got about replacing the agitator shaft? I have taken the inner tub out. Am I going to have to take the transmission out of the cabinet?
Post# 445549 , Reply# 1   6/29/2010 at 13:32 (5,050 days old) by swestoyz (Cedar Falls, IA)   |   | |
Jed - it would require a complete transmission teardown to replace the agitator shaft. I've had luck in the past by drilling and using an easy out to remove the broken off agitator bolt.
I'll be posting a thread shortly documenting a complete rebuild of a '59 Kenmore, which should help give some prespective on the tasks required to change out the agitator shaft, if so desired. Good luck, Ben |
Post# 445611 , Reply# 2   6/29/2010 at 16:46 (5,050 days old) by surgilator_68 (Maryland)   |   | |
