Thread Number: 29802
KitchenAid (Hobart) Imperial 21 KDI-21A Classic |
Post# 453184 , Reply# 1   7/30/2010 at 21:44 (5,018 days old) by pdub (Portland, Oregon)   |   | |
Not sure if you want to save it as it may be a simple fix that someone here in the club can walk you through. Could it be that the plastic door interlock switch got snapped off where it depresses the switch behind the inside of the door to tell the dishwasher the door is closed? It is located at the top of the right hand side of the frame on the front of the tank. If this switch doesn't get pushed in when the door gets closed you will have a non working dishwasher. Best of luck as it looks like it's in very good shape otherwise.
