Thread Number: 30235
Adjusting water level on LG (Model WM2050) |
Post# 458502   8/22/2010 at 17:01 (4,996 days old) by labboy (SD, CA)   |   | |
Is it possible to raise the water level on an LG front loader (Model WM2050)? I love the machine but would like it to have slightly higher water levels. It has a feature called "Water Plus" but it does not do it for me. Also, when using Water Plus one cannot select the Extra Rinse option. If anyone has instructions on how to adjust the water level, please let me know.
Thanks |
Post# 458600 , Reply# 1   8/23/2010 at 00:05 (4,995 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 458603 , Reply# 2   8/23/2010 at 00:17 (4,995 days old) by powerfin64 (Yakima, Washington)   |   | |
Post# 458812 , Reply# 4   8/23/2010 at 22:31 (4,994 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 458936 , Reply# 5   8/24/2010 at 16:02 (4,994 days old) by bertrum ()   |   | |
Hi Ladyboy, You can adjust the pressure switch just be very carefull and mark the screw position when you test it, just half a turn at at time though!. Good luck |
Post# 459041 , Reply# 6   8/25/2010 at 06:20 (4,993 days old) by mrb627 (Buford, GA)   |   | |
I found that if a load of clothes needed to be washed in the maximum amount of water, I would run them through a rinse & spin first with a low speed spin. Then the load would be good and heavy. When the machine would begin dry load sensing, it would detect the load at the maximum load size and use more water through the cycle. Tedious, but it did work.
Malcolm |
Post# 459068 , Reply# 7   8/25/2010 at 08:26 (4,993 days old) by labboy (SD, CA)   |   | |
Post# 459103 , Reply# 8   8/25/2010 at 11:26 (4,993 days old) by logixx (Germany)   |   | |
Post# 459120 , Reply# 9   8/25/2010 at 12:16 (4,993 days old) by mrb627 (Buford, GA)   |   | |
