Thread Number: 30513
Want to fix Maytag CA206 washing machine |
Post# 461675 , Reply# 1   9/6/2010 at 16:20 (4,980 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 461677 , Reply# 2   9/6/2010 at 16:23 (4,980 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 461701 , Reply# 3   9/6/2010 at 17:47 (4,980 days old) by JaredH ()   |   | |
IN COPPERTONE!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?!?! This is a standard Capacity machine! OMG!!!! PICS PLEASE!!!!!! :D |
Post# 461743 , Reply# 4   9/6/2010 at 20:03 (4,980 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 461782 , Reply# 6   9/6/2010 at 21:48 (4,980 days old) by wnlewis (122 East First Street Newton Kansas 67114)   |   | |
Here is the Dryer. Neal |
Post# 461935 , Reply# 7   9/7/2010 at 16:15 (4,979 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 462036 , Reply# 9   9/7/2010 at 22:36 (4,979 days old) by qsd-dan (West)   |   | |
Post# 462278 , Reply# 11   9/8/2010 at 22:06 (4,978 days old) by wnlewis (122 East First Street Newton Kansas 67114)   |   | |
Doesn't look like that picture got up. Let me try again. Neal |
Post# 462281 , Reply# 12   9/8/2010 at 22:13 (4,978 days old) by qsd-dan (West)   |   | |
Have you had a chance to narrow down the leak? Just remove the 2 Phillip screw near the bottom of the front panel (they're hiding underneath that lip at the edges of the front panel) and lift the front panel up 90 degrees (this disengages the top clips). Very quick and easy to do! From there, do a small load of clothes (or just use water) and look for leaks while the machine is agitating/spinning (be careful of the transmission while it's in the spin mode!!).
Hopefully it's just a leaky hose, but it may be time to replace the stem and seal. Is the spin cycle noisy? If not, the tub bearing should still be fine. |
Post# 462446 , Reply# 13   9/9/2010 at 16:32 (4,977 days old) by JaredH ()   |   | |
Easy life 4 sure! |
Post# 462610 , Reply# 14   9/10/2010 at 16:05 (4,976 days old) by goatfarmer (South Bend, home of Champions)   |   | |
