Thread Number: 31493
testing the maytag atlantis
Post# 475087   11/14/2010 at 17:34 (4,911 days old) by cfz2882 (Belle Fourche,SD)
got around to checking the 2000 vintage maytag atlantis i just
got from a junkyard;dry spin and wash went well but problem
was apparent when the wet spin came-would not pump out because
the belt was slipping on the motor pulley,motor can move on
it's base via plastic bushings that move in slotted holes-
there is a spring clip to provide some tension on the belt
but not enough-motor just sits where you position it on the
base-might be a spring missing somewhere?-if not i might have
to "improve" the design and add one...
