Thread Number: 31554
KDI-16 Wash Arm Support problem |
Post# 476195 , Reply# 2   11/18/2010 at 22:01 (4,907 days old) by rollermatic (cincinnati)   |   | |
"sit" on or in the drain unit. it is the top half of the pump and bolts to the bottom half. the hydrosweep wash arm spins on it.
i know they had them on e bay last week for about 16 bucks. i have bought about 4 or 5 over the last 2 years. unless i am wrong (stevet will know) the ones listed will fit the 16 and 17 models only. i have used them on some of my 17's. it's an easy fix if you buy one. it bolts on with 4 simple little bolts. the hydrosweep just slides on it's spindle as you probably already know. i know that some of mine have gotten sticky and not turned freely due to crud build up in the center bearing of the hydrosweep itself. after i cleaned it out good with steel wool the hydrosweeps turned freely again. for 16 bucks plus shipping a new wash arm support is not a bad idea and hopefully will solve your problem. you can also find hydrosweeps on e bay too. i bought one new last year, never used for about 20 bucks! good luck with it! |
