Thread Number: 31675
Another Neptune Adventure-Converting 4000 to a 7500 |
Post# 477737 , Reply# 1   11/26/2010 at 19:41 (4,899 days old) by fordtech ()   |   | |
Here is the removal of the old control panel and components. |
Post# 477738 , Reply# 2   11/26/2010 at 19:41 (4,899 days old) by fordtech ()   |   | |
Removal of the front door and front panel assembly of the base |
Post# 477740 , Reply# 3   11/26/2010 at 19:43 (4,899 days old) by fordtech ()   |   | |
Removal of the bulkhead, drum front and filter duct |
Post# 477741 , Reply# 4   11/26/2010 at 19:43 (4,899 days old) by fordtech ()   |   | |
Removed drum and belt for full access |
Post# 477742 , Reply# 5   11/26/2010 at 19:44 (4,899 days old) by fordtech ()   |   | |
Next step is removal of the wiring harness |
Post# 477747 , Reply# 7   11/26/2010 at 19:47 (4,899 days old) by fordtech ()   |   | |
Now we just reinstall all those major components back in reverse order |
Post# 477748 , Reply# 8   11/26/2010 at 19:49 (4,899 days old) by fordtech ()   |   | |
Then following the wiring schematic install the new control board and top and you now have 97 percent of the job done! |
Post# 477751 , Reply# 9   11/26/2010 at 19:50 (4,899 days old) by fordtech ()   |   | |
The final touch for me was recieving and assembling the matching door. Of course if you are upgrading a model 5500 dryer you will already have the correct door! |
Post# 477773 , Reply# 11   11/26/2010 at 20:19 (4,899 days old) by nmassman44 (Brooksville Florida)   |   | |
Interesting thread....I did check out your last thread about the muck in the washer and the mold issues...that last photo on this thread is telling...your not using an HE detergent with your machine. You did all that cleaning and its going to be mucked up again and in no time. JUst my opinion and I am sure there others that noticed.
Post# 477878 , Reply# 13   11/27/2010 at 14:00 (4,899 days old) by supremewhirlpol ()   |   | |
fordtech: now the only thing that is left is a bearing job, for the washer, and electronics troubleshooting, then you be the master of Neptune repair. |
