Thread Number: 31792
Frigidaie 1-18 |
Post# 479578 , Reply# 1   12/5/2010 at 11:23 (4,891 days old) by christfr (st louis mo)   |   | |
Post# 479604 , Reply# 3   12/5/2010 at 14:08 (4,891 days old) by joelippard (Hickory)   |   | |
Post# 479605 , Reply# 4   12/5/2010 at 14:10 (4,891 days old) by autowash (st louis )   |   | |
Hey Chris, is continues to advance through the spin cycle but will not run at high speed. The other slow spin cycles also seem to work. |
Post# 479627 , Reply# 5   12/5/2010 at 15:27 (4,891 days old) by christfr (st louis mo)   |   | |
well im not the expert here but i will find out more info for you. the best i can tell is that the timer has a spot that tells the motor to kick into high. so if the rest of the cycle is fine and the timer is prob running as it should there has to be some sort of motor issue but ill get a hold of mark hes really good with motors
Post# 479646 , Reply# 6   12/5/2010 at 17:06 (4,890 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 479799 , Reply# 7   12/6/2010 at 06:59 (4,890 days old) by autowash (st louis )   |   | |
Thanks Chris and Combo, I will check the model number. Chris, when you talk to Mark, let him know I may be getting rid of the Kenmore 70's I got a while back. Thanks guys, this is such a great site! |
Post# 479926 , Reply# 8   12/6/2010 at 17:29 (4,889 days old) by christfr (st louis mo)   |   | |
Post# 479956 , Reply# 9   12/6/2010 at 21:13 (4,889 days old) by laundromat (Hilo, Hawaii)   |   | |
Not that this has anything to do with your speed issue but, I remember the last few years of the 1-18s they had this feature that kept the agitation at a lower speed until the water level was a bit higher so the water would not leak all over the place. I had their Elite series that had the "Tuch-N-Wash" feature and lots of push buttons.When I hooked it up,the agitator came on at the mini level I had set it for but didn't rev up to the set speed until the water reached half the way up the agitator post.
