Thread Number: 32186
The Queen is Sidelined... |
Post# 485525 , Reply# 1   12/31/2010 at 17:06 (4,864 days old) by KenmoreBD (Mass, usa )   |   | |
Oh no it is never fun not haveing a working washer, Im not tech guy but it sounds like maybe the motor went bad? Or maybe the winding im not sure if speedqueen motors have that part or not? |
Post# 485530 , Reply# 2   12/31/2010 at 17:32 (4,864 days old) by yogitunes (New Jersey)   |   | |
Post# 485531 , Reply# 3   12/31/2010 at 17:33 (4,864 days old) by nmassman44 (Brooksville Florida)   |   | |
Wow it does sound to me that the motor is dead and not a belt. If it was a belt the washer would be able to drain since the pump is a direct drive right off the motor. And the motor has only a 5 year warranty on it and it looks like if your machine is 5 years old you may have to cough up for a new motor. Not to mention the labor involved.
Oh that just plain stinks. |
Post# 485551 , Reply# 5   12/31/2010 at 18:50 (4,864 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 485613 , Reply# 9   1/1/2011 at 08:18 (4,863 days old) by mtn1584 (USA)   |   | |
I also have a SQ washer, I would call Alliance and let them know, if there are any out of pocket expenses, I bet they will cover them! Let us know what happens, and I wish you good luck. Mike |
Post# 486207 , Reply# 10   1/3/2011 at 21:10 (4,861 days old) by kqkenmore (memphis tn)   |   | |
Post# 486209 , Reply# 11   1/3/2011 at 21:25 (4,861 days old) by danmantn (Tennessee)   |   | |
Call Alliance as mentioned--they've always been a class act on even the smallest of my concerns. Basically if it's under warranty, you can go on their site, locate an authorized servicer and they take care of what's still under warranty. I would call first to make sure if your warranty is still in effect though.
Post# 486679 , Reply# 15   1/6/2011 at 06:21 (4,858 days old) by mrb627 (Buford, GA)   |   | |
Post# 486747 , Reply# 16   1/6/2011 at 11:59 (4,858 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 487369 , Reply# 21   1/8/2011 at 17:32 (4,856 days old) by mrb627 (Buford, GA)   |   | |
Post# 487386 , Reply# 22   1/8/2011 at 18:31 (4,856 days old) by nmassman44 (Brooksville Florida)   |   | |
With mine the motor is running fine but I dont think that the idler is clamping too tight on the belt so it isnt spinning as fast as it usually does. Agitation mode there are no issues, but spin is a different story. Some loads extract fine others not so much. Towels it seems to have issues and then jeans. With mine it just started doing that so I am wondering what the hell. All I could think of is that the basement in my situation might be the issue. It could be too cool.
Post# 487388 , Reply# 23   1/8/2011 at 18:37 (4,856 days old) by yogitunes (New Jersey)   |   | |
Post# 487398 , Reply# 24   1/8/2011 at 19:33 (4,856 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If the idler pulley had a problem the belt should have been changed as the extra slipping is hard on the belt. The weakest part of the SQ TL washers is the belt. Your problem is not likely the motor. We are an authorized SQ service dealer but keep in mind it is very hard to repair machines over the internet.
Post# 487508 , Reply# 27   1/9/2011 at 09:58 (4,855 days old) by mrb627 (Buford, GA)   |   | |
I have always believed that belts on any machine should be changed on a regular basis. As a belt wears, it will ride deeper in the pulley channel resulting in a loss of performance. I used to change the belt on my grandma's kenmore annually. Grandma liked to load up the kenmore so things could hardly move. But that is another story. Since the belts on a Speed Queen do the clutching of the spin as water is pumped out, they should be changed on a regular cycle.
Malcolm |
Post# 487568 , Reply# 28   1/9/2011 at 14:45 (4,855 days old) by DanManTN (Tennessee)   |   | |
Post# 489276 , Reply# 32   1/16/2011 at 07:48 (4,848 days old) by mrb627 (Buford, GA)   |   | |
Post# 489279 , Reply# 33   1/16/2011 at 08:09 (4,848 days old) by coldspot66 (Plymouth, Mass)   |   | |
He should have changed the belt!!!!!!!!!!! |
Post# 489296 , Reply# 34   1/16/2011 at 09:57 (4,848 days old) by danmantn (Tennessee)   |   | |
Post# 489304 , Reply# 36   1/16/2011 at 10:32 (4,848 days old) by danmantn (Tennessee)   |   | |
Yeah, I think as an industry, traditional top loaders are at the end of the road...I would be surprised to see anything new coming out--just the ability to get one will soon be a luxury. All R&D I'm sure is going to front load and efficient top loaders.
Previously the only time I would use warm rinse was so the tub would fill faster - but someone posted on the board that it would help with wrinkles - haven't verified that yet with my '03 WP. |
Post# 489318 , Reply# 37   1/16/2011 at 11:28 (4,848 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 489326 , Reply# 38   1/16/2011 at 13:15 (4,848 days old) by mrb627 (Buford, GA)   |   | |
So, the question I have is this. How long does it take the machine to pump out a tub full of water? After the water is pumped clear of the machine, how long does it take for your machine to reach top speed.
Perhaps someone with a functioning machine can time theors and relate the statistics. I suspect that any laziness of the machine to achieve top speed spin in a timely fashion is due to a worn drive belt or something binding the tub preventing spinning freedom. Of course, the first place to start is probably gonna be changing out the belt. Malcolm |
Post# 489330 , Reply# 39   1/16/2011 at 13:36 (4,848 days old) by appnut (TX)   |   | |
I haven't kept up with the most fine tune points about this saga, but my question is this--with a mechanical timer, what is preventing you from resetting the machine at the beginning of the final spin, once finished, and let it spin again and hopefully it reaches top spin speed before the conclusion of the spin period, especially since it's not having to deal with pumping out a tub of water and sopping wet laundry.
Post# 489360 , Reply# 41   1/16/2011 at 16:53 (4,848 days old) by neptunebob (Pittsburgh, PA)   |   | |
Angus,
First thing I would do tomorrow is call "Ted" (the owner?) up and tell him to fire the ass----- "technician" who did not repair the machine. Mistreatment of a customer who did cooperate as you did has been upheld in the courts as reason for termination (and Not collecting unemployment). It sounds like you have been entirely reasonable and did not deserve to be treated that way. Then the second call would be to Alliance to find out who they could send to fix your washer and tell them your experience with this service company. If Alliance cares at all, they will dump that company and send out a technician who knows what they are doing. If they (Alliance) cannot recommend another technician ask them to send the parts at no charge - probably cost them less than to have service and with all of us here you can fix your washer. By the way, I am Irish (from both sides of Ireland) and I can shout too! |
Post# 489372 , Reply# 42   1/16/2011 at 17:50 (4,848 days old) by nmassman44 (Brooksville Florida)   |   | |
To answer Bob's question...as I am having this issue as well with my washer...I have done the reset the timer to the final spin and for some reason sometimes it will reach top speed but most times it does not. I am doing laundry again tomorrow and I am going to see if she still does the slow spin again. I usually dont have an issue with the first 2 loads...its the loads after that I have problems with. I ruled out the fact that the rinse water is ice cold this time of year so that shouldnt matter. I too know the sounds of my machine and I know when its at top speed.
Agitation isnt affected. |
Post# 489403 , Reply# 43   1/16/2011 at 19:39 (4,848 days old) by mtn1584 (USA)   |   | |
Yes ,being Italian, I do understand the blind rage...LOL, please keep us posted as to what happens, I hope you get it resolved soon, there definitely more servicers in Connecticut. Take care, Mike |
Post# 489410 , Reply# 45   1/16/2011 at 20:11 (4,848 days old) by appnut (TX)   |   | |
Post# 489428 , Reply# 46   1/16/2011 at 20:52 (4,848 days old) by neptunebob (Pittsburgh, PA)   |   | |
Could it be possible that somehow the motor is running on the delicate speed during spin? That might explain the dampness, but is that possible?
Which also brings up: Years ago, didn't Consumer Reports say that Speed Queen and Amana had higher-than-average spin speeds? Would the current design be higher than average? |
Post# 489429 , Reply# 47   1/16/2011 at 20:54 (4,848 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 489446 , Reply# 49   1/16/2011 at 21:32 (4,848 days old) by mtn1584 (USA)   |   | |
Oh yeah, and let's not forget these are the same machines that get used constantly in laundromats. |
Post# 489523 , Reply# 50   1/17/2011 at 08:23 (4,847 days old) by mrb627 (Buford, GA)   |   | |
Post# 489962 , Reply# 51   1/18/2011 at 20:51 (4,846 days old) by tbolt25 (Kentucky)   |   | |
I also have a Speed Queen (model #AWN412) top-load washer, and from reading these posts, I wonder what I should do to avoid having any of this trouble with my AWN412 washer? |
Post# 490022 , Reply# 52   1/19/2011 at 06:20 (4,845 days old) by mrb627 (Buford, GA)   |   | |
I wonder if there is a measurement that is used to determine when a belt is worn beyond its usefulness. I suppose everyone with a machine over a year old could order in a new belt and compare the thickness. Then make your own judgement on when to replace. I suppose a worn belt would also reduce the number of strokes per minute as well as top spin speed.
Malcolm |
Post# 490033 , Reply# 53   1/19/2011 at 06:44 (4,845 days old) by mtn1584 (USA)   |   | |
SIMPLE.........Don't overload the machine! |
Post# 490044 , Reply# 54   1/19/2011 at 08:15 (4,845 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The best way to tell if you need a new belt for any machine is to compare it to a new one. If you can see noticeable wear, glazing, cracking, stretching and piles of black belt dust under the motor pulley you may need a new belt. Severe overloading is not good for any washer or dryer but I believe far more damage is done in the long run with under-loading. Most of the parts that will ware out in a washer, dryer and dishwasher will do so based on the number of cycles the machine is run not an occasional large load. Almost all W&Ds today are built to commercial standards and we actually see very few problems that can be attributed to overloading. All three types of machines are far more energy efficient with full loads, also full washer loads balance better and actually reduce ware on bearings and suspension systems, this is especially true of the new FL and faster spinning hi efficiency TL washers today.
Post# 492115 , Reply# 55   1/28/2011 at 14:11 (4,836 days old) by danmantn (Tennessee)   |   | |
Post# 493186 , Reply# 57   2/1/2011 at 20:37 (4,832 days old) by danmantn (Tennessee)   |   | |
Post# 493286 , Reply# 59   2/2/2011 at 07:14 (4,831 days old) by mrb627 (Buford, GA)   |   | |
Post# 495953 , Reply# 68   2/12/2011 at 13:09 (4,821 days old) by mrb627 (Buford, GA)   |   | |
Post# 495959 , Reply# 69   2/12/2011 at 13:33 (4,821 days old) by appnut (TX)   |   | |
