Thread Number: 32393
Hotpoint Dryer DLB2650BCLWH no heat. |
Post# 488696 , Reply# 1   1/13/2011 at 13:50 (4,851 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 488700 , Reply# 2   1/13/2011 at 14:04 (4,851 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Check the coils, is there a broken turn of the spiral somewhere? That has been my luck with electric dryers, simple broken coil. But while you're in there, check all wires everywhere, to the sensors and limit switches, etc. Pictures won't hurt. Are you a good enough electrician to take the coil assembly out and test it?
Post# 488969 , Reply# 4   1/14/2011 at 19:09 (4,850 days old) by ifreemantoo ()   |   | |
I'll have to get working on your suggestions and will report back. |
Post# 488989 , Reply# 5   1/14/2011 at 21:26 (4,849 days old) by ifreemantoo ()   |   | |
All wires look good. |
Post# 489070 , Reply# 6   1/15/2011 at 10:20 (4,849 days old) by bajaespuma (Connecticut)   |   | |
Lately, lots of dud dryers in my neck of the woods have been caused by those cheap coin-sized thermostats that attach to the vents, manifolds etc. that regulate high heat limit and cool down periods. You might want to enlist someone with electrical skills with a voltage meter to see if any of them are defective. We happen to have a neighbor who is an electrician and he did this for a lot of us. They're usually cheap and easy to replace especially if you have a local "do it yourself" appliance parts store.
Post# 489161 , Reply# 8   1/15/2011 at 19:31 (4,848 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 489212 , Reply# 10   1/15/2011 at 21:30 (4,848 days old) by macboy91si (Frankfort, KY)   |   | |
