Thread Number: 32871
Kenmore Dishwasher Dial Settings |
Post# 495019 , Reply# 1   2/8/2011 at 19:40 (4,824 days old) by appnut (TX)   |   | |
Post# 495022 , Reply# 2   2/8/2011 at 19:44 (4,824 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
sometime b also means econo cycle i remember since near the end of the 80 in my old home the kitchen was redone and the dishwasher replace by an 80 90 inglis whirlpool dishwasher and the cycle dial had a for normal high temp wash and pots and pans b stand for Econo cycle and c stand for rinse and hold cycle and a picture would help as well
Post# 495206 , Reply# 4   2/9/2011 at 11:59 (4,824 days old) by cycla-fabric (New Jersey (Northern))   |   | |
Post# 495207 , Reply# 5   2/9/2011 at 12:02 (4,824 days old) by mrb627 (Buford, GA)   |   | |
Post# 495240 , Reply# 6   2/9/2011 at 13:53 (4,824 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 495247 , Reply# 7   2/9/2011 at 14:27 (4,824 days old) by mrb627 (Buford, GA)   |   | |
Post# 495315 , Reply# 8   2/9/2011 at 18:51 (4,823 days old) by peteski50 (New York)   |   | |
Post# 495316 , Reply# 9   2/9/2011 at 18:56 (4,823 days old) by appnut (TX)   |   | |
OK, here we go. If yo have B button pushed in and turn the dial to B position, you will get a prewash, main wash, and two rinses. That would be referred to as Normal Wassh cycle. Button B pushed in and the timer dial moved mini-wash, you will get the main wash and two rinses. That would be referred to as light soil or low energy cycle. Now, with the two buttons over A The left button is for Pots and Pans. If this machine follows teh standard whirlpool cycle sequence, A with Pots and Pans button selected, you will get a PreWash that will heat the water to a certain temperature, then a rinse, then the main wash and will be eated to a set temperature; after the main wash will be the two rinses. The 2nd of those two rinses will also heat the4 water to a set temperature. While the machine is heating the water on the Pots and Pans cycle, it will continue to circulate the water and wash the load and the timer will be paused until the temperature is set. The left of the two buttons over is for Heavy soil. It's the sequence of the Pots & Pans cycle, but no cycle delay for heating wateer. So its Prewash, ri8nse, main wash, and two rinses. There is another little cycle between the two words "off" on the dials. Taht is a rinse & hold cycle to prewash a partial load dirty dishes and hold them until you are ready to run a full load through a complete usual cycle. If the machine is functioning properly, this is probably the best cleaning dishwasher ever made, particularly with the Pots & Pans cycle. The joke is that it would take the chrome off a trailer hitch or the chrome off a truck bumper. Would llvoe to see a picture of the interior. |
Post# 495548 , Reply# 11   2/10/2011 at 17:59 (4,823 days old) by roto204 (Tucson, AZ)   |   | |
Post# 495806 , Reply# 13   2/11/2011 at 21:07 (4,821 days old) by appnut (TX)   |   | |
A +Pots & Pans, remember it's delaying progeress through the cycles so it heats the wateer in the prewash (1st fill), main wash, and final rinse. Those heating delays can take 20 to 30 minutes each depending upon your water heater temp and water cooling down in the supply pipes. As for the utelsils not getting clean, try nort to put pots and pans and big items such as that at the front of the lower rack cuz that will block the water getting to the basket on the door. Put your large dinner pots and similar items in the front. (Although, it just occurred to me your utensil basket may be in the bottom rack and not mounted on the door--which is the case for the Whirlpool produced Kenmores in the U.S.) Just make sure your mixing items in the baskets and not letting them all nest tog4ether with identical items only in the same compartment.
And you are very welcome. Glad I could contribute to the problem solving. This post was last edited 02/11/2011 at 21:56 |
